TLV62090 / Tolerance of output discharge resistor
Other Parts Discussed in Thread: TLV62090
Hi Everyone,
Please let me ask about tolerance of output discharge resistor (Rod) of TLV62090. I know that only typical value is stated in electrical characteristic as 200ohm, so the Rod is not measured at final test and so you can not provide guaranteed value. But our customer need to know the rough tolerance of this 200ohm. Can you confirm the design spec of Rod?
Sonoki / Japan Disty
  • I'm not sure why this would be critical for an application. If you are trying to estimate the discharge time/rate, the variations in load and Cout would surely be as significant as the variation of this single resistor.
    I would estimate a +/-30% variation on such a typical parameter.
