TPS61256 YFF package application note ?
Expert 7280 points
Other Parts Discussed in Thread: TPS61256
Dear team,
Do we have a document/application note, similar to sbva017, which would provide the design information for 250um bump like for the TPS61256 ?
The following topic brings an answer, but I would prefer if we could provide an app note..:
Thanks a lot for your help !
PA
  • here is the application engineer of TPS61256YFF. sorry but I didn't find a application note special for the 250um bump PCB guideline. i'll check with the package team if they have similar material and will come to you if i get something new.
    thanks
    Jasper Li
  • Hi PA,
    Sorry, we don't have a general app note of TPS61256 about all the information in summary, though you can get PCB layout guide, package dimension and so on in datasheet and user's guide.
    BR
    Gene
  • Dear Jasper,
    Thank you for your answer !
    My customer would appreciate some more information.
    FYI, PCB layout is not a problem, the question is to know which solder mask opening to use:
    - using a 300um opening as recommended in the document I found (see the link in my previous post) only left ~100um between two pads in a 400um pitch package. Doesn't it increase the risk of short circuit ?
    Thanks again !
    PA
  • please refer this application note www.ti.com/lit/snva009
    our EVMs are build based on this AN. About the risk, i think it also relate to the PCB and assembling manufacturer. the customer may need to discuss with their manufacturer if it is OK.
    thanks
    Jasper Li
