BQ34Z100-G1 ChemID change
Other Parts Discussed in Thread: EV2400, BQSTUDIO, BQ34Z100-G1
I am working with a standard SLA battery and want to change the Chem ID on the fuel gauge to an 0x080x version from the default 0x0107 set in the fuel gauge.
I am looking for some more information as to the I2C commands required/which data locations to change that will allow me to change the CHEM_ID. I am able to read the data using the control subcommands without any problems. When writing to the chem_id block, the write operation seems successful, based on the acks and bits seen on the oscilloscope, but reading back the chem_id data still gives me the default value of 0x0107. Does the static_chem_chksum play a role in this and if so, what is the way this checksum, not the block data checksum, is calculated?
The I2C commands provided in a different post for configuring the data flash was perfect https://e2e.ti.com/support/power_management/battery_management/f/180/t/416308#pi317195=2  and something similar for changing the chem id would be greatly appreciated.
I do not have the EVM and therefore no access to the software mentioned in the majority of the forum posts.
Martin
  • Martin,
    The ChemID is just the designator for the chemistry data programmed into the device. There are several tables of data that are loaded when the chemistry is changed and you do not have access to the memory addresses, or tables, to change that data. You do not have to use the EVM to use bqStudio. You can use the program as long as you have access to the I2C bus, an EV2300 to EV2400 adapter and a computer with bqStudio installed. I would recommend using this setup until you have configured the device and run the optimization cycle. It will be a lot easier to develop the pack using the tools that we provide.
    Tom
  • Hi Tom,
    Thanks for your quick reply.
    From what I am understanding here, please correct me if I am wrong, is that the golden image .DFI that is created can be embedded in our microprocessor code (is the .DFI written in C code?) which will allow the microprocessor to read the file and send the configuration/data to the fuel gauge using the I2C commands provided in the "Going to Production With the bq34z1xx" document.
    In addition, will the golden image .DFI file change the memory addresses and tables that I do not have access to without the need of using bqStudio or EV2400 at that point in time (production)?
    Martin
  • Martin
    The bq34z100-G1 does not officially support .dfi files, but you can use the procedure in the Going to Production document to export and import them. The dfi file will contain the chemistry data. I would recommend using bqStudio for development and your uC can transfer the dfi file or the srec file to the device in production. The bqStudio program will also export a .df.fs file that can be used with the uC.
    Tom
  • Hi Tom,
    I have done as you have suggested and purchased an ev2400 to connect to our board and bqStudio. The initial chemical id i have chosen is 0803 for our 20Ah 12V SLA battery. Before I begin a calibration, I would like to ensure that the values entered seemed reasonable for the algorithm before starting calibration. The SOC and remaining capacity are showing as 0 which i believe is normal until the calibration is done. Please see the attached .gg file. Excel can open the delimited text file.
    Due to our high charging voltage, the taper current is set at 1A for our battery charger (charges the battery at 2A) as the regulation voltage will change with temperature and aging batteries.
    For the calibration procedure, is it required to discharge at C/20 or C/5 or will a slower discharge rate still work such as C/50? There is also a relaxation period involved in the calibration; is this when the charger is completely disconnected from the battery or can the battery remain on a pulse/float charge?
    Martin
    * Texas Instruments Data Flash File
    * File created Tue May 05 13:29:34 2015
    * Device Number 100
    * Firmware Version 0.16
    * Build Number not available
    * Order Number not available
    * bqz Device Number 100
    * bqz Firmware Version 0.16
    * bqz Build Number 17
    * Field Order: Class name	 Subclass name	 Parameter name	 Parameter Value	 Units
    Configuration	Safety	OT Chg	55	1degC
    Configuration	Safety	OT Chg Time	6	Seconds
    Configuration	Safety	OT Chg Recovery	50	1degC
    Configuration	Safety	OT Dsg	60	1degC
    Configuration	Safety	OT Dsg Time	2	Seconds
    Configuration	Safety	OT Dsg Recovery	55	1degC
    Configuration	Charge Inhibit Cfg	Chg Inhibit Temp Low	0	1degC
    Configuration	Charge Inhibit Cfg	Chg Inhibit Temp High	45	1degC
    Configuration	Charge Inhibit Cfg	Temp Hys	5	1degC
    Configuration	Charge	Suspend Low Temp	-5	1degC
    Configuration	Charge	Suspend High Temp	55	1degC
    Configuration	Charge	Pb EFF Efficiency	100	%
    Configuration	Charge	Pb Temp Comp	24.96	%
    Configuration	Charge	Pb Drop Off Percent	96	%
    Configuration	Charge	Pb Reduction Rate	10	%
    Configuration	Charge Termination	Taper Current	1000	mAmp
    Configuration	Charge Termination	Min Taper Capacity	1000	mAmpHr
    Configuration	Charge Termination	Cell Taper Voltage	100	mVolt
    Configuration	Charge Termination	Current Taper Window	40	Seconds
    Configuration	Charge Termination	TCA Set %	99	Percent
    Configuration	Charge Termination	TCA Clear %	95	Percent
    Configuration	Charge Termination	FC Set %	-1	Percent
    Configuration	Charge Termination	FC Clear %	98	Percent
    Configuration	Charge Termination	DODatEOC Delta T	10	1degC
    Configuration	Charge Termination	NiMH Delta Temp	3	1degC
    Configuration	Charge Termination	NiMH Delta Temp Time	180	Seconds
    Configuration	Charge Termination	NiMH Hold Off  Time	100	Seconds
    Configuration	Charge Termination	NiMH Hold Off Current	240	mAmp
    Configuration	Charge Termination	NiMH Hold Off  Temp	25	1degC
    Configuration	Charge Termination	NiMH Cell Negative Delta Volt	17	mVolt
    Configuration	Charge Termination	NiMH Cell Negative Delta Time	16	Seconds
    Configuration	Charge Termination	NiMH Cell Neg Delta Qual Volt	4200	mVolt
    Configuration	Data	Manufacture Date	1/1/1980	Day + Mo*32 + (Yr -1980)*256
    Configuration	Data	Serial Number	200	hex
    Configuration	Data	Cycle Count	10	Count
    Configuration	Data	CC Threshold	2948	mAmpHr
    Configuration	Data	Max Error Limit	100	%
    Configuration	Data	Design Capacity	20000	MilliAmpHour
    Configuration	Data	Design Energy	24000	MilliWattHour
    Configuration	Data	SOH Load I	-400	MilliAmp
    Configuration	Data	Cell Charge Voltage T1-T2	2450	mV
    Configuration	Data	Cell Charge Voltage T2-T3	2450	mV
    Configuration	Data	Cell Charge Voltage T3-T4	2450	mV
    Configuration	Data	Charge Current T1-T2	10	Percent
    Configuration	Data	Charge Current  T2-T3	50	Percent
    Configuration	Data	Charge Current  T3-T4	30	Percent
    Configuration	Data	JEITA T1	-40	degC
    Configuration	Data	JEITA T2	-10	degC
    Configuration	Data	JEITA T3	50	degC
    Configuration	Data	JEITA T4	85	degC
    Configuration	Data	Design Energy Scale	10	Number
    Configuration	Data	Device Name	bq34z100-G1	-
    Configuration	Data	Manufacturer Name	Texas Inst.	-
    Configuration	Data	Device Chemistry	PB	-
    Configuration	Discharge	SOC1 Set Threshold	150	mAh
    Configuration	Discharge	SOC1 Clear Threshold	175	mAh
    Configuration	Discharge	SOCF Set Threshold	75	mAh
    Configuration	Discharge	SOCF Clear Threshold	100	mAh
    Configuration	Discharge	Cell BL Set Volt Threshold	2800	mVolt
    Configuration	Discharge	Cell BL Set Volt Time	2	Seconds
    Configuration	Discharge	Cell BL Clear Volt Threshold	2900	mVolt
    Configuration	Discharge	Cell BH Set Volt Threshold	4300	mVolt
    Configuration	Discharge	Cell BH Volt Time	2	Seconds
    Configuration	Discharge	Cell BH  Clear Volt Threshold	4200	mVolt
    Configuration	Discharge	Cycle Delta	0.05	%
    Configuration	Manufacturer Data	Pack Lot Code	0	hex
    Configuration	Manufacturer Data	PCB Lot Code	0	hex
    Configuration	Manufacturer Data	Firmware Version	0	hex
    Configuration	Manufacturer Data	Hardware Revision	0	hex
    Configuration	Manufacturer Data	Cell Revision	0	hex
    Configuration	Manufacturer Data	DF Config Version	0	hex
    Configuration	Lifetime Data	Lifetime Max Temp	85	1degC
    Configuration	Lifetime Data	Lifetime Min Temp	-40	1degC
    Configuration	Lifetime Data	Lifetime Max Chg Current	0	mAmp
    Configuration	Lifetime Data	Lifetime Max Dsg Current	0	mA
    Configuration	Lifetime Data	Lifetime Max Pack Voltage	800	20mV
    Configuration	Lifetime Data	Lifetime Min Pack Voltage	500	20mV
    Configuration	Lifetime Temp Samples	LT Flash Cnt	0	Count
    Configuration	Registers	Pack Configuration	9.00E+01	flags
    Configuration	Registers	Pack Configuration B	ae	flags
    Configuration	Registers	Pack Configuration C	37	flags
    Configuration	Registers	LED_Comm Configuration	0	flags
    Configuration	Registers	Alert Configuration	0	flags
    Configuration	Registers	Number of series cell	6	num
    Configuration	Lifetime Resolution	LT Temp Res	1	1degC
    Configuration	Lifetime Resolution	LT Cur Res	100	mA
    Configuration	Lifetime Resolution	LT V Res	1	20mV
    Configuration	Lifetime Resolution	LT Update Time	60	Seconds
    Configuration	LED Display	LED Hold Time	4	Num
    Configuration	Power	Flash Update OK Cell Volt	1600	mVolt
    Configuration	Power	Sleep Current	10	mAmp
    Configuration	Power	FS Wait	0	Seconds
    System Data	Manufacturer Info	Block A 0	0	hex
    System Data	Manufacturer Info	Block A 1	0	hex
    System Data	Manufacturer Info	Block A 2	0	hex
    System Data	Manufacturer Info	Block A 3	0	hex
    System Data	Manufacturer Info	Block A 4	0	hex
    System Data	Manufacturer Info	Block A 5	0	hex
    System Data	Manufacturer Info	Block A 6	0	hex
    System Data	Manufacturer Info	Block A 7	0	hex
    System Data	Manufacturer Info	Block A 8	0	hex
    System Data	Manufacturer Info	Block A 9	0	hex
    System Data	Manufacturer Info	Block A 10	0	hex
    System Data	Manufacturer Info	Block A 11	0	hex
    System Data	Manufacturer Info	Block A 12	0	hex
    System Data	Manufacturer Info	Block A 13	0	hex
    System Data	Manufacturer Info	Block A 14	0	hex
    System Data	Manufacturer Info	Block A 15	0	hex
    System Data	Manufacturer Info	Block A 16	0	hex
    System Data	Manufacturer Info	Block A 17	0	hex
    System Data	Manufacturer Info	Block A 18	0	hex
    System Data	Manufacturer Info	Block A 19	0	hex
    System Data	Manufacturer Info	Block A 20	0	hex
    System Data	Manufacturer Info	Block A 21	0	hex
    System Data	Manufacturer Info	Block A 22	0	hex
    System Data	Manufacturer Info	Block A 23	0	hex
    System Data	Manufacturer Info	Block A 24	0	hex
    System Data	Manufacturer Info	Block A 25	0	hex
    System Data	Manufacturer Info	Block A 26	0	hex
    System Data	Manufacturer Info	Block A 27	0	hex
    System Data	Manufacturer Info	Block A 28	0	hex
    System Data	Manufacturer Info	Block A 29	0	hex
    System Data	Manufacturer Info	Block A 30	0	hex
    System Data	Manufacturer Info	Block A 31	0	hex
    Gas Gauging	IT Cfg	Load Select	3	Number
    Gas Gauging	IT Cfg	Load Mode	0	Number
    Gas Gauging	IT Cfg	Res Current	10	mAmp
    Gas Gauging	IT Cfg	Max Res Factor	50	num
    Gas Gauging	IT Cfg	Min Res Factor	1	num
    Gas Gauging	IT Cfg	Ra Filter	500	num
    Gas Gauging	IT Cfg	Min PassedChg NiMH-LA 1st Qmax	50	%
    Gas Gauging	IT Cfg	Maximum Qmax Change	100	%
    Gas Gauging	IT Cfg	Cell Terminate Voltage	1750	mVolt
    Gas Gauging	IT Cfg	Cell Term V Delta	100	mVolt
    Gas Gauging	IT Cfg	ResRelax Time	500	Seconds
    Gas Gauging	IT Cfg	User Rate-mA	0	MilliAmp
    Gas Gauging	IT Cfg	User Rate-Pwr	360	mW/cW
    Gas Gauging	IT Cfg	Reserve Cap-mAh	1000	MilliAmpHour
    Gas Gauging	IT Cfg	Reserve Energy	1200	mWh/cWh
    Gas Gauging	IT Cfg	Max Scale Back Grid	4	num
    Gas Gauging	IT Cfg	Cell Min DeltaV	0	mVolt
    Gas Gauging	IT Cfg	Ra Max Delta	15	%
    Gas Gauging	IT Cfg	Design Resistance	42	mOhms
    Gas Gauging	IT Cfg	Reference Grid	4	-
    Gas Gauging	IT Cfg	Qmax Max Delta %	10	mAmpHour
    Gas Gauging	IT Cfg	Max Res Scale	32000	Num
    Gas Gauging	IT Cfg	Min Res Scale	1	Num
    Gas Gauging	IT Cfg	Fast Scale Start SOC	10	%
    Gas Gauging	IT Cfg	Charge Hys V Shift	40	mVolt
    Gas Gauging	IT Cfg	Smooth Relax Time	1000	s
    Gas Gauging	Current Thresholds	Dsg Current Threshold	60	mAmp
    Gas Gauging	Current Thresholds	Chg Current Threshold	75	mAmp
    Gas Gauging	Current Thresholds	Quit Current	40	mAmp
    Gas Gauging	Current Thresholds	Dsg Relax Time	60	Seconds
    Gas Gauging	Current Thresholds	Chg Relax Time	60	Seconds
    Gas Gauging	Current Thresholds	Cell Max IR Correct	400	mV
    Gas Gauging	State	Qmax Cell 0	1000	mAmpHr
    Gas Gauging	State	Cycle Count	0	num
    Gas Gauging	State	Update Status	0	num
    Gas Gauging	State	Cell V at Chg Term	2450	mVolt
    Gas Gauging	State	Avg I Last Run	-299	mAmp
    Gas Gauging	State	Avg P Last Run	-1131	MilliWattHour
    Gas Gauging	State	Cell Delta Voltage	2	mVolt
    Gas Gauging	State	T Rise	2	Num
    Gas Gauging	State	T Time Constant	1000	Num
    Ra Tables	Ra0 Table	Ra Flag	ff55	Hex
    Ra Tables	Ra0 Table	Ra 0	34	Num
    Ra Tables	Ra0 Table	Ra 1	31	Num
    Ra Tables	Ra0 Table	Ra 2	28	Num
    Ra Tables	Ra0 Table	Ra 3	24	Num
    Ra Tables	Ra0 Table	Ra 4	23	Num
    Ra Tables	Ra0 Table	Ra 5	23	Num
    Ra Tables	Ra0 Table	Ra 6	23	Num
    Ra Tables	Ra0 Table	Ra 7	25	Num
    Ra Tables	Ra0 Table	Ra 8	27	Num
    Ra Tables	Ra0 Table	Ra 9	30	Num
    Ra Tables	Ra0 Table	Ra 10	35	Num
    Ra Tables	Ra0 Table	Ra 11	45	Num
    Ra Tables	Ra0 Table	Ra 12	121	Num
    Ra Tables	Ra0 Table	Ra 13	268	Num
    Ra Tables	Ra0 Table	Ra 14	429	Num
    Ra Tables	Ra0x Table	Ra Flag	ffff	Hex
    Ra Tables	Ra0x Table	Ra 0	34	Num
    Ra Tables	Ra0x Table	Ra 1	31	Num
    Ra Tables	Ra0x Table	Ra 2	28	Num
    Ra Tables	Ra0x Table	Ra 3	24	Num
    Ra Tables	Ra0x Table	Ra 4	23	Num
    Ra Tables	Ra0x Table	Ra 5	23	Num
    Ra Tables	Ra0x Table	Ra 6	23	Num
    Ra Tables	Ra0x Table	Ra 7	25	Num
    Ra Tables	Ra0x Table	Ra 8	27	Num
    Ra Tables	Ra0x Table	Ra 9	30	Num
    Ra Tables	Ra0x Table	Ra 10	35	Num
    Ra Tables	Ra0x Table	Ra 11	45	Num
    Ra Tables	Ra0x Table	Ra 12	121	Num
    Ra Tables	Ra0x Table	Ra 13	268	Num
    Ra Tables	Ra0x Table	Ra 14	429	Num
    Calibration	Data	CC Gain	10.584	mohm
    Calibration	Data	CC Delta	10.564	mohm
    Calibration	Data	CC Offset	-1454	num
    Calibration	Data	Board Offset	26	num
    Calibration	Data	Int Temp Offset	0	degC
    Calibration	Data	Ext Temp Offset	0	degC
    Calibration	Data	Voltage Divider	18036	mVolt
    Calibration	Current	Deadband	5	mAmp
    Security	Codes	Sealed to Unsealed	36720414	hex
    Security	Codes	Unsealed to Full	ffffffff	hex
    Security	Codes	Authen Key3	1234567	hex
    Security	Codes	Authen Key2	89abcdef	hex
    Security	Codes	Authen Key1	fedcba98	hex
    Security	Codes	Authen Key0	76543210	hex
  • Martin,
    You should not expect good gauging until the ChemID has been verified, the pack has been calibrated and the optimization cycle has been completed. I would set the taper current to 500mA and leave the Taper Capacity at 25mAh. All of the other parameters look reasonable.
    Are you referring to the optimization cycle for the C/20 or C/5 rate? The current must be greater than C/10. I would use C/8. The charger and load should be removed during the rest periods.
    Tom
  • Hi Tom,
    It seems I am unable to set the FC flag upon charge termination in the calibration process. The new parameters have been posted which I have modified to pass the test more easily, yet it is still failing. I believe the change in capacity is not large enough to qualify as a complete charge during the time period. For more information about our system, please email me as these are confidential.
    There seems to be many ways of calibrating this fuel gauge floating around in various app notes and this forum itself. However, I have tried to use the method you have posted here as the chemid is the same,
    1) Issue the Reset (41) command.
    2) Issue the IT Enable (21) command.
    3) Charge the pack until the FC bit is set.
    4) Remove the charger and let the pack rest until the OCVTAKEN flag gets set.
    5) Discharge the pack at a C/8 rate to the 3500mV and remove the load.
    6) Let the pack rest until the OCVTAKEN flag gets set. OMax should update and Update Status should increment to 05.
    7) Go back to Step 3) and continue though Step 6)
    I am using this method as the battery discharge/charge cycle takes quite a long time and I would like to verify the FC bit can be set before discharging the battery fully.
    Martin
    Tue May 19 13:52:49 EDT 2015
    Device Name = bq34z100G1
    Firmware Version = 0_16
    Sample,DateTime,ElapsedTime,Control,CtrlStatus,StateofCharge,MaxError,RemCap,FullChgCap,Voltage,Current,AvgCurrent,Temperature,AverageTimeToEmpty,AverageTimeToFull,AvailableEnergy,AveragePower,InternalTemperature,CycleCnt,StateofHealth,ChargeVoltage,ChargeCurrent,PackConfig,Flags,Flags B,GridNumber,LearnedStatus,DoDatEOC,Qstart,TrueRC,TrueFCC,StateTime,DOD0PassedQ,DOD0Time,DOD0,QmaxDOD0,QmaxPassedQ,QmaxTime,LogRowTime(ms),LogStatus
    1,2015-05-19 13:52:53,4.000,0x0013,0x0013,0,100,0,0,12942,-8,-1144,24.6,0,65535,0,-2,26.6,18,5,14580,10000,0x09E1,0x1117,0x0400,1,4,0,0,-74,0,78,60,2,0,0,60,2,885,SUCCESS
    2,2015-05-19 13:52:57,8.001,0x0003,0x0003,0,100,0,0,13398,1788,-537,24.6,0,65535,0,399,26.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-72,0,2,58,2,0,0,58,2,880,SUCCESS
    3,2015-05-19 13:53:01,12.001,0x0003,0x0003,0,100,0,0,13446,1786,22,24.6,65535,153,0,400,26.3,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-70,0,6,56,2,0,0,56,2,888,SUCCESS
    4,2015-05-19 13:53:05,16.001,0x0003,0x0003,0,100,0,0,13488,1784,445,24.6,65535,7,0,401,26.3,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-68,0,10,54,2,0,0,54,2,882,SUCCESS
    5,2015-05-19 13:53:09,20.002,0x0003,0x0003,0,100,0,0,13536,1782,767,24.6,65535,4,0,402,26.2,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-66,0,14,52,2,0,0,52,2,891,SUCCESS
    6,2015-05-19 13:53:16,26.525,0x0003,0x0003,0,100,0,0,13602,1780,1109,24.6,65535,3,0,404,26.2,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-63,0,21,49,3,0,0,49,3,887,SUCCESS
    7,2015-05-19 13:53:21,31.501,0x0003,0x0003,0,100,0,0,13656,1779,1304,24.6,65535,3,0,405,26.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-60,0,26,46,3,0,0,46,3,890,SUCCESS
    8,2015-05-19 13:53:25,35.496,0x0003,0x0003,0,100,0,0,13692,1778,1418,24.6,65535,2,0,406,26.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-58,0,30,44,3,0,0,44,3,888,SUCCESS
    9,2015-05-19 13:53:29,39.490,0x0003,0x0003,0,100,0,0,13734,1777,1504,24.6,65535,2,0,407,26.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-56,0,34,42,3,0,0,42,3,888,SUCCESS
    10,2015-05-19 13:53:33,43.498,0x0003,0x0003,0,100,0,0,13782,1775,1570,24.6,65535,2,0,408,26.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-54,0,38,40,3,0,0,40,3,888,SUCCESS
    11,2015-05-19 13:53:37,47.492,0x0003,0x0003,0,100,0,0,13824,1775,1619,24.6,65535,2,0,409,26.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-52,0,42,38,3,0,0,38,3,889,SUCCESS
    12,2015-05-19 13:53:41,51.503,0x0003,0x0003,0,100,0,0,13872,1774,1656,24.6,65535,2,0,410,26.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-50,0,46,36,3,0,0,36,3,888,SUCCESS
    13,2015-05-19 13:53:45,55.496,0x0003,0x0003,0,100,0,0,13914,1773,1684,24.6,65535,2,0,411,26.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-48,0,50,34,3,0,0,34,3,888,SUCCESS
    14,2015-05-19 13:53:49,59.489,0x0003,0x0003,0,100,0,0,13968,1772,1705,24.6,65535,2,0,413,26.2,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-47,0,54,32,3,0,0,32,3,889,SUCCESS
    15,2015-05-19 13:53:53,63.498,0x0003,0x0003,0,100,0,0,14016,1771,1721,24.6,65535,2,0,414,26.3,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-45,0,58,30,3,0,0,30,3,890,SUCCESS
    16,2015-05-19 13:53:57,67.493,0x0003,0x0003,0,100,0,0,14070,1770,1733,24.6,65535,1,0,415,26.3,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-43,0,62,28,3,0,0,28,3,889,SUCCESS
    17,2015-05-19 13:54:01,71.503,0x0003,0x0003,0,100,0,0,14136,1766,1741,24.6,65535,1,0,416,26.3,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-41,0,66,27,3,0,0,27,3,888,SUCCESS
    18,2015-05-19 13:54:05,75.494,0x0003,0x0003,0,100,0,0,14196,1755,1746,24.6,65535,1,0,415,26.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-39,0,69,25,3,0,0,25,3,889,SUCCESS
    19,2015-05-19 13:54:09,79.506,0x0003,0x0003,0,100,0,0,14268,1715,1743,24.6,65535,1,0,408,26.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-37,0,73,23,3,0,0,23,3,888,SUCCESS
    20,2015-05-19 13:54:13,83.500,0x0003,0x0003,0,100,0,0,14310,1625,1723,24.6,65535,1,0,388,26.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-35,0,77,21,3,0,0,21,3,888,SUCCESS
    21,2015-05-19 13:54:17,87.493,0x0003,0x0003,0,100,0,0,14328,1513,1681,24.6,65535,1,0,361,26.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-34,0,81,20,3,0,0,19,3,888,SUCCESS
    22,2015-05-19 13:54:21,91.501,0x0003,0x0003,0,100,0,0,14328,1403,1623,24.6,65535,1,0,335,26.6,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-32,0,85,18,3,0,0,18,3,889,SUCCESS
    23,2015-05-19 13:54:25,95.494,0x0003,0x0003,0,100,0,0,14328,1309,1556,24.6,65535,1,0,313,26.7,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-30,0,89,16,3,0,0,16,3,890,SUCCESS
    24,2015-05-19 13:54:29,99.506,0x0003,0x0003,0,100,0,0,14334,1222,1483,24.6,65535,1,0,292,26.7,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-29,0,93,15,3,0,0,15,3,888,SUCCESS
    25,2015-05-19 13:54:33,103.500,0x0003,0x0003,0,100,0,0,14328,1145,1408,24.6,65535,1,0,273,26.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-28,0,97,14,3,0,0,14,3,887,SUCCESS
    26,2015-05-19 13:54:37,107.507,0x0003,0x0003,0,100,0,0,14328,1073,1333,24.6,65535,1,0,256,26.9,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-27,0,101,13,3,0,0,13,3,890,SUCCESS
    27,2015-05-19 13:54:41,111.503,0x0003,0x0003,0,100,0,0,14334,1014,1261,24.6,65535,1,0,242,26.9,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-25,0,105,11,3,0,0,11,3,888,SUCCESS
    28,2015-05-19 13:54:45,115.496,0x0003,0x0003,0,100,0,0,14334,959,1193,24.6,65535,1,0,229,27.0,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-24,0,109,10,3,0,0,10,3,889,SUCCESS
    29,2015-05-19 13:54:49,119.507,0x0003,0x0003,0,100,0,0,14340,910,1129,24.6,65535,1,0,217,27.0,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-23,0,113,9,3,0,0,9,3,887,SUCCESS
    30,2015-05-19 13:54:53,123.499,0x0003,0x0003,0,100,0,0,14346,865,1069,24.6,65535,1,0,207,27.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-22,0,117,8,3,0,0,8,3,888,SUCCESS
    31,2015-05-19 13:54:57,127.509,0x0003,0x0003,0,100,0,0,14352,820,1013,24.6,65535,0,0,196,27.1,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-21,0,121,7,3,0,0,7,3,889,SUCCESS
    32,2015-05-19 13:55:01,131.502,0x0003,0x0003,0,100,0,0,14352,781,961,24.6,65535,0,0,187,27.2,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-20,0,125,6,3,0,0,6,3,889,SUCCESS
    33,2015-05-19 13:55:05,135.511,0x0003,0x0003,0,100,0,0,14358,744,912,24.6,65535,0,0,178,27.2,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-20,0,129,6,3,0,0,6,3,888,SUCCESS
    34,2015-05-19 13:55:09,139.505,0x0003,0x0003,0,100,0,0,14358,707,866,24.6,65535,0,0,169,27.2,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-19,0,133,5,3,0,0,5,3,889,SUCCESS
    35,2015-05-19 13:55:13,143.499,0x0003,0x0003,0,100,0,0,14358,676,823,24.6,65535,0,0,162,27.3,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-18,0,137,4,3,0,0,4,3,889,SUCCESS
    36,2015-05-19 13:55:17,147.509,0x0003,0x0003,0,100,0,0,14364,649,783,24.6,65535,0,0,155,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-17,0,141,3,3,0,0,3,3,889,SUCCESS
    37,2015-05-19 13:55:21,151.504,0x0003,0x0003,0,100,0,0,14370,620,746,24.6,65535,0,0,148,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-17,0,145,3,3,0,0,3,3,887,SUCCESS
    38,2015-05-19 13:55:25,155.510,0x0003,0x0003,0,100,0,0,14370,594,711,24.6,65535,0,0,142,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-16,0,149,2,3,0,0,2,3,890,SUCCESS
    39,2015-05-19 13:55:29,159.507,0x0003,0x0003,0,100,0,0,14370,569,679,24.6,65535,0,0,136,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-15,0,153,1,3,0,0,1,3,888,SUCCESS
    40,2015-05-19 13:55:33,163.499,0x0003,0x0003,0,100,0,0,14376,549,650,24.6,65535,0,0,132,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-15,0,157,1,3,0,0,1,3,888,SUCCESS
    41,2015-05-19 13:55:37,167.508,0x0003,0x0013,0,100,0,0,14232,0,580,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,161,0,3,0,0,0,3,889,SUCCESS
    42,2015-05-19 13:55:41,171.503,0x0013,0x0013,0,100,0,0,14232,0,441,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,165,0,3,0,0,0,3,888,SUCCESS
    43,2015-05-19 13:55:45,175.513,0x0013,0x0013,0,100,0,0,14232,0,335,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,169,0,3,0,0,0,3,888,SUCCESS
    44,2015-05-19 13:55:49,179.506,0x0013,0x0013,0,100,0,0,14232,0,254,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,173,0,3,0,0,0,3,889,SUCCESS
    45,2015-05-19 13:55:53,183.514,0x0013,0x0013,0,100,0,0,14232,0,193,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,177,0,3,0,0,0,3,889,SUCCESS
    46,2015-05-19 13:55:57,187.508,0x0013,0x0013,0,100,0,0,13998,0,147,24.5,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,181,0,3,0,0,0,3,890,SUCCESS
    47,2015-05-19 13:56:01,191.504,0x0013,0x0013,0,100,0,0,13998,0,112,24.5,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,185,0,3,0,0,0,3,888,SUCCESS
    48,2015-05-19 13:56:05,195.512,0x0013,0x0013,0,100,0,0,13998,0,85,24.5,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,189,0,3,0,0,0,3,889,SUCCESS
    49,2015-05-19 13:56:09,199.505,0x0013,0x0013,0,100,0,0,13998,0,64,24.5,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,193,0,3,0,0,0,3,889,SUCCESS
    50,2015-05-19 13:56:13,203.514,0x0013,0x0013,0,100,0,0,13998,0,49,24.5,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,197,0,3,0,0,0,3,890,SUCCESS
    51,2015-05-19 13:56:17,207.509,0x0013,0x0013,0,100,0,0,13950,0,37,24.5,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,201,0,3,0,0,0,3,890,SUCCESS
    52,2015-05-19 13:56:21,211.520,0x0013,0x0013,0,100,0,0,13950,0,28,24.5,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,205,0,3,0,0,0,3,887,SUCCESS
    53,2015-05-19 13:56:25,215.512,0x0013,0x0013,0,100,0,0,13950,0,21,24.5,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,209,0,3,0,0,0,3,888,SUCCESS
    54,2015-05-19 13:56:29,219.506,0x0013,0x0013,0,100,0,0,13950,0,16,24.5,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,213,0,3,0,0,0,3,889,SUCCESS
    55,2015-05-19 13:56:33,223.515,0x0013,0x0013,0,100,0,0,13950,0,12,24.5,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,217,0,3,0,0,0,3,890,SUCCESS
    56,2015-05-19 13:56:37,227.509,0x0013,0x0013,0,100,0,0,13908,0,9,24.6,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,1,0,3,0,0,0,3,889,SUCCESS
    57,2015-05-19 13:56:41,231.519,0x0013,0x0013,0,100,0,0,13908,0,7,24.6,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,5,0,3,0,0,0,3,888,SUCCESS
    58,2015-05-19 13:56:45,235.511,0x0013,0x0013,0,100,0,0,13908,0,5,24.6,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,9,0,3,0,0,0,3,890,SUCCESS
    59,2015-05-19 13:56:49,239.522,0x0013,0x0013,0,100,0,0,13908,0,4,24.6,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,13,0,3,0,0,0,3,889,SUCCESS
    60,2015-05-19 13:56:53,243.516,0x0013,0x0013,0,100,0,0,13908,0,3,24.6,65535,0,0,0,27.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,17,0,3,0,0,0,3,888,SUCCESS
    61,2015-05-19 13:56:57,247.508,0x0013,0x0013,0,100,0,0,13878,0,2,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,21,0,3,0,0,0,3,890,SUCCESS
    62,2015-05-19 13:57:01,251.519,0x0013,0x0013,0,100,0,0,13878,0,2,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,25,0,3,0,0,0,3,889,SUCCESS
    63,2015-05-19 13:57:05,255.512,0x0013,0x0013,0,100,0,0,13878,0,1,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,29,0,4,0,0,0,4,890,SUCCESS
    64,2015-05-19 13:57:09,259.522,0x0013,0x0013,0,100,0,0,13878,0,1,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,33,0,4,0,0,0,4,889,SUCCESS
    65,2015-05-19 13:57:13,263.516,0x0013,0x0013,0,100,0,0,13878,0,1,24.6,65535,0,0,0,27.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,37,0,4,0,0,0,4,888,SUCCESS
    66,2015-05-19 13:57:17,267.524,0x0013,0x0013,0,100,0,0,13848,0,1,24.5,65535,0,0,0,27.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,41,0,4,0,0,0,4,891,SUCCESS
    67,2015-05-19 13:57:21,271.519,0x0013,0x0013,0,100,0,0,13848,0,0,24.5,65535,65535,0,0,27.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,45,0,4,0,0,0,4,889,SUCCESS
    68,2015-05-19 13:57:25,275.512,0x0013,0x0013,0,100,0,0,13848,0,0,24.5,65535,65535,0,0,27.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,49,0,4,0,0,0,4,890,SUCCESS
    69,2015-05-19 13:57:29,279.522,0x0013,0x0013,0,100,0,0,13848,0,0,24.5,65535,65535,0,0,27.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,53,0,4,0,0,0,4,890,SUCCESS
    70,2015-05-19 13:57:33,283.516,0x0013,0x0013,0,100,0,0,13848,0,0,24.5,65535,65535,0,0,27.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,57,0,4,0,0,0,4,889,SUCCESS
    71,2015-05-19 13:57:37,287.525,0x0013,0x0013,0,100,0,0,13824,0,0,24.5,65535,65535,0,0,27.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,61,0,4,0,0,0,4,890,SUCCESS
    72,2015-05-19 13:57:41,291.519,0x0013,0x0013,0,100,0,0,13824,0,0,24.5,65535,65535,0,0,27.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,65,0,4,0,0,0,4,889,SUCCESS
    73,2015-05-19 13:57:45,295.512,0x0013,0x0013,0,100,0,0,13824,0,0,24.5,65535,65535,0,0,27.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,69,0,4,0,0,0,4,889,SUCCESS
    74,2015-05-19 13:57:49,299.523,0x0013,0x0013,0,100,0,0,13824,0,0,24.5,65535,65535,0,0,27.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,73,0,4,0,0,0,4,889,SUCCESS
    75,2015-05-19 13:57:53,303.516,0x0013,0x0013,0,100,0,0,13824,0,0,24.5,65535,65535,0,0,27.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,77,0,4,0,0,0,4,889,SUCCESS
    76,2015-05-19 13:57:57,307.524,0x0013,0x0013,0,100,0,0,13800,0,0,24.4,65535,65535,0,0,26.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,81,0,4,0,0,0,4,890,SUCCESS
    77,2015-05-19 13:58:01,311.520,0x0013,0x0013,0,100,0,0,13800,0,0,24.4,65535,65535,0,0,26.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,85,0,4,0,0,0,4,889,SUCCESS
    78,2015-05-19 13:58:05,315.529,0x0013,0x0013,0,100,0,0,13800,0,0,24.4,65535,65535,0,0,26.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,89,0,4,0,0,0,4,889,SUCCESS
    79,2015-05-19 13:58:09,319.523,0x0013,0x0013,0,100,0,0,13800,0,0,24.4,65535,65535,0,0,26.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,93,0,4,0,0,0,4,889,SUCCESS
    80,2015-05-19 13:58:13,323.515,0x0013,0x0013,0,100,0,0,13800,0,0,24.4,65535,65535,0,0,26.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,97,0,4,0,0,0,4,890,SUCCESS
    81,2015-05-19 13:58:17,327.525,0x0013,0x0013,0,100,0,0,13782,0,0,24.4,65535,65535,0,0,26.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,101,0,4,0,0,0,4,890,SUCCESS
    82,2015-05-19 13:58:21,331.521,0x0013,0x0013,0,100,0,0,13782,0,0,24.4,65535,65535,0,0,26.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,105,0,4,0,0,0,4,888,SUCCESS
    83,2015-05-19 13:58:25,335.529,0x0013,0x0013,0,100,0,0,13782,0,0,24.4,65535,65535,0,0,26.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,109,0,4,0,0,0,4,889,SUCCESS
    84,2015-05-19 13:58:29,339.522,0x0013,0x0013,0,100,0,0,13782,0,0,24.4,65535,65535,0,0,26.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,113,0,4,0,0,0,4,889,SUCCESS
    85,2015-05-19 13:58:33,343.531,0x0013,0x0013,0,100,0,0,13782,0,0,24.4,65535,65535,0,0,26.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,117,0,4,0,0,0,4,890,SUCCESS
    86,2015-05-19 13:58:37,347.526,0x0013,0x0013,0,100,0,0,13764,0,0,24.3,65535,65535,0,0,26.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,121,0,4,0,0,0,4,890,SUCCESS
    87,2015-05-19 13:58:41,351.521,0x0013,0x0013,0,100,0,0,13764,0,0,24.3,65535,65535,0,0,26.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,125,0,4,0,0,0,4,888,SUCCESS
    88,2015-05-19 13:58:45,355.528,0x0013,0x0013,0,100,0,0,13764,0,0,24.3,65535,65535,0,0,26.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,129,0,4,0,0,0,4,889,SUCCESS
    89,2015-05-19 13:58:49,359.523,0x0013,0x0013,0,100,0,0,13764,0,0,24.3,65535,65535,0,0,26.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,133,0,4,0,0,0,4,889,SUCCESS
    90,2015-05-19 13:58:53,363.532,0x0013,0x0013,0,100,0,0,13764,0,0,24.3,65535,65535,0,0,26.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,137,0,4,0,0,0,4,889,SUCCESS
    91,2015-05-19 13:58:57,367.525,0x0013,0x0013,0,100,0,0,13746,0,0,24.4,65535,65535,0,0,26.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,141,0,4,0,0,0,4,890,SUCCESS
    92,2015-05-19 13:59:01,371.536,0x0013,0x0013,0,100,0,0,13746,0,0,24.4,65535,65535,0,0,26.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,145,0,4,0,0,0,4,888,SUCCESS
    93,2015-05-19 13:59:05,375.528,0x0013,0x0013,0,100,0,0,13746,0,0,24.4,65535,65535,0,0,26.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,149,0,4,0,0,0,4,890,SUCCESS
    94,2015-05-19 13:59:09,379.524,0x0013,0x0013,0,100,0,0,13746,0,0,24.4,65535,65535,0,0,26.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,153,0,4,0,0,0,4,889,SUCCESS
    95,2015-05-19 13:59:13,383.533,0x0013,0x0013,0,100,0,0,13746,0,0,24.4,65535,65535,0,0,26.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,157,0,4,0,0,0,4,888,SUCCESS
    96,2015-05-19 13:59:17,387.525,0x0013,0x0013,0,100,0,0,13728,0,0,24.3,65535,65535,0,0,26.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,161,0,4,0,0,0,4,890,SUCCESS
    97,2015-05-19 13:59:21,391.537,0x0013,0x0013,0,100,0,0,13728,0,0,24.3,65535,65535,0,0,26.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,165,0,4,0,0,0,4,888,SUCCESS
    98,2015-05-19 13:59:25,395.529,0x0013,0x0013,0,100,0,0,13728,0,0,24.3,65535,65535,0,0,26.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,169,0,4,0,0,0,4,889,SUCCESS
    99,2015-05-19 13:59:29,399.524,0x0013,0x0013,0,100,0,0,13728,0,0,24.3,65535,65535,0,0,26.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,173,0,4,0,0,0,4,888,SUCCESS
    100,2015-05-19 13:59:33,403.532,0x0013,0x0013,0,100,0,0,13728,0,0,24.3,65535,65535,0,0,26.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,177,0,4,0,0,0,4,889,SUCCESS
    101,2015-05-19 13:59:37,407.526,0x0013,0x0013,0,100,0,0,13716,0,0,24.3,65535,65535,0,0,26.2,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,181,0,4,0,0,0,4,890,SUCCESS
    102,2015-05-19 13:59:41,411.537,0x0013,0x0013,0,100,0,0,13716,0,0,24.3,65535,65535,0,0,26.2,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,185,0,4,0,0,0,4,888,SUCCESS
    103,2015-05-19 13:59:45,415.529,0x0013,0x0013,0,100,0,0,13716,0,0,24.3,65535,65535,0,0,26.2,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,189,0,4,0,0,0,4,889,SUCCESS
    104,2015-05-19 13:59:49,419.538,0x0013,0x0013,0,100,0,0,13716,0,0,24.3,65535,65535,0,0,26.2,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,193,0,4,0,0,0,4,890,SUCCESS
    105,2015-05-19 13:59:53,423.534,0x0013,0x0013,0,100,0,0,13716,0,0,24.3,65535,65535,0,0,26.2,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,197,0,4,0,0,0,4,888,SUCCESS
    106,2015-05-19 13:59:57,427.526,0x0013,0x0013,0,100,0,0,13698,0,0,24.3,65535,65535,0,0,26.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,201,0,4,0,0,0,4,890,SUCCESS
    107,2015-05-19 14:00:01,431.537,0x0013,0x0013,0,100,0,0,13698,0,0,24.3,65535,65535,0,0,26.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,205,0,4,0,0,0,4,887,SUCCESS
    108,2015-05-19 14:00:05,435.529,0x0013,0x0013,0,100,0,0,13698,0,0,24.3,65535,65535,0,0,26.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,209,0,4,0,0,0,4,889,SUCCESS
    109,2015-05-19 14:00:09,439.540,0x0013,0x0013,0,100,0,0,13698,0,0,24.3,65535,65535,0,0,26.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,213,0,4,0,0,0,4,889,SUCCESS
    110,2015-05-19 14:00:13,443.533,0x0013,0x0013,0,100,0,0,13698,0,0,24.3,65535,65535,0,0,26.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,217,0,4,0,0,0,4,889,SUCCESS
    111,2015-05-19 14:00:17,447.541,0x0013,0x0013,0,100,0,0,13686,0,0,24.3,65535,65535,0,0,26.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,221,0,4,0,0,0,4,890,SUCCESS
    112,2015-05-19 14:00:21,451.535,0x0013,0x0013,0,100,0,0,13686,0,0,24.3,65535,65535,0,0,26.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,225,0,4,0,0,0,4,891,SUCCESS
    113,2015-05-19 14:00:25,455.530,0x0013,0x0013,0,100,0,0,13686,0,0,24.3,65535,65535,0,0,26.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,229,0,4,0,0,0,4,889,SUCCESS
    114,2015-05-19 14:00:29,459.540,0x0013,0x0013,0,100,0,0,13686,0,0,24.3,65535,65535,0,0,26.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,233,0,4,0,0,0,4,889,SUCCESS
    115,2015-05-19 14:00:33,463.532,0x0013,0x0013,0,100,0,0,13686,0,0,24.3,65535,65535,0,0,26.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,237,0,4,0,0,0,4,889,SUCCESS
    116,2015-05-19 14:00:37,467.541,0x0013,0x0013,0,100,0,0,13674,0,0,24.3,65535,65535,0,0,25.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,241,0,4,0,0,0,4,891,SUCCESS
    117,2015-05-19 14:00:41,471.537,0x0013,0x0013,0,100,0,0,13674,0,0,24.3,65535,65535,0,0,25.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,245,0,4,0,0,0,4,889,SUCCESS
    118,2015-05-19 14:00:45,475.546,0x0013,0x0013,0,100,0,0,13674,0,0,24.3,65535,65535,0,0,25.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,249,0,4,0,0,0,4,889,SUCCESS
    119,2015-05-19 14:00:49,479.540,0x0013,0x0013,0,100,0,0,13674,0,0,24.3,65535,65535,0,0,25.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,253,0,5,0,0,0,5,888,SUCCESS
    120,2015-05-19 14:00:53,483.532,0x0013,0x0013,0,100,0,0,13674,0,0,24.3,65535,65535,0,0,25.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,257,0,5,0,0,0,5,891,SUCCESS
    121,2015-05-19 14:00:57,487.542,0x0013,0x0013,0,100,0,0,13662,0,0,24.2,65535,65535,0,0,25.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,261,0,5,0,0,0,5,891,SUCCESS
    122,2015-05-19 14:01:01,491.538,0x0013,0x0013,0,100,0,0,13662,0,0,24.2,65535,65535,0,0,25.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,265,0,5,0,0,0,5,887,SUCCESS
    123,2015-05-19 14:01:05,495.545,0x0013,0x0013,0,100,0,0,13662,0,0,24.2,65535,65535,0,0,25.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,269,0,5,0,0,0,5,889,SUCCESS
    124,2015-05-19 14:01:09,499.540,0x0013,0x0013,0,100,0,0,13662,0,0,24.2,65535,65535,0,0,25.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,273,0,5,0,0,0,5,889,SUCCESS
    125,2015-05-19 14:01:13,503.534,0x0013,0x0013,0,100,0,0,13662,0,0,24.2,65535,65535,0,0,25.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,277,0,5,0,0,0,5,889,SUCCESS
    126,2015-05-19 14:01:17,507.543,0x0013,0x0013,0,100,0,0,13650,0,0,24.3,65535,65535,0,0,25.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,281,0,5,0,0,0,5,890,SUCCESS
    127,2015-05-19 14:01:21,511.537,0x0013,0x0013,0,100,0,0,13650,0,0,24.3,65535,65535,0,0,25.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,285,0,5,0,0,0,5,888,SUCCESS
    128,2015-05-19 14:01:25,515.545,0x0013,0x0013,0,100,0,0,13650,0,0,24.3,65535,65535,0,0,25.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,289,0,5,0,0,0,5,890,SUCCESS
    129,2015-05-19 14:01:29,519.540,0x0013,0x0013,0,100,0,0,13650,0,0,24.3,65535,65535,0,0,25.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,293,0,5,0,0,0,5,890,SUCCESS
    130,2015-05-19 14:01:33,523.549,0x0013,0x0013,0,100,0,0,13650,0,0,24.3,65535,65535,0,0,25.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,297,0,5,0,0,0,5,889,SUCCESS
    131,2015-05-19 14:01:37,527.542,0x0013,0x0013,0,100,0,0,13644,0,0,24.3,65535,65535,0,0,25.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,301,0,5,0,0,0,5,890,SUCCESS
    132,2015-05-19 14:01:41,531.537,0x0013,0x0013,0,100,0,0,13644,0,0,24.3,65535,65535,0,0,25.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,305,0,5,0,0,0,5,889,SUCCESS
    133,2015-05-19 14:01:45,535.546,0x0013,0x0013,0,100,0,0,13644,0,0,24.3,65535,65535,0,0,25.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,309,0,5,0,0,0,5,889,SUCCESS
    134,2015-05-19 14:01:49,539.540,0x0013,0x0013,0,100,0,0,13644,0,0,24.3,65535,65535,0,0,25.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,313,0,5,0,0,0,5,889,SUCCESS
    135,2015-05-19 14:01:53,543.549,0x0013,0x0013,0,100,0,0,13644,0,0,24.3,65535,65535,0,0,25.5,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,317,0,5,0,0,0,5,889,SUCCESS
    136,2015-05-19 14:01:57,547.542,0x0013,0x0013,0,100,0,0,13632,0,0,24.2,65535,65535,0,0,25.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,321,0,5,0,0,0,5,891,SUCCESS
    137,2015-05-19 14:02:01,551.554,0x0013,0x0013,0,100,0,0,13632,0,0,24.2,65535,65535,0,0,25.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,325,0,5,0,0,0,5,888,SUCCESS
    138,2015-05-19 14:02:05,555.545,0x0013,0x0013,0,100,0,0,13632,0,0,24.2,65535,65535,0,0,25.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,329,0,5,0,0,0,5,890,SUCCESS
    139,2015-05-19 14:02:09,559.540,0x0013,0x0013,0,100,0,0,13632,0,0,24.2,65535,65535,0,0,25.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,333,0,5,0,0,0,5,889,SUCCESS
    140,2015-05-19 14:02:13,563.550,0x0013,0x0013,0,100,0,0,13632,0,0,24.2,65535,65535,0,0,25.4,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,337,0,5,0,0,0,5,889,SUCCESS
    141,2015-05-19 14:02:17,567.543,0x0013,0x0013,0,100,0,0,13620,0,0,24.2,65535,65535,0,0,25.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,341,0,5,0,0,0,5,890,SUCCESS
    142,2015-05-19 14:02:21,571.553,0x0013,0x0013,0,100,0,0,13620,0,0,24.2,65535,65535,0,0,25.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,345,0,5,0,0,0,5,888,SUCCESS
    143,2015-05-19 14:02:25,575.546,0x0013,0x0013,0,100,0,0,13620,0,0,24.2,65535,65535,0,0,25.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,349,0,5,0,0,0,5,889,SUCCESS
    144,2015-05-19 14:02:29,579.557,0x0013,0x0013,0,100,0,0,13620,0,0,24.2,65535,65535,0,0,25.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,353,0,5,0,0,0,5,889,SUCCESS
    145,2015-05-19 14:02:33,583.550,0x0013,0x0013,0,100,0,0,13620,0,0,24.2,65535,65535,0,0,25.3,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,357,0,5,0,0,0,5,889,SUCCESS
    146,2015-05-19 14:02:37,587.542,0x0013,0x0013,0,100,0,0,13614,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,361,0,5,0,0,0,5,891,SUCCESS
    147,2015-05-19 14:02:41,591.553,0x0013,0x0013,0,100,0,0,13614,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,365,0,5,0,0,0,5,890,SUCCESS
    148,2015-05-19 14:02:45,595.547,0x0013,0x0013,0,100,0,0,13614,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,369,0,5,0,0,0,5,889,SUCCESS
    149,2015-05-19 14:02:49,599.557,0x0013,0x0013,0,100,0,0,13614,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,373,0,5,0,0,0,5,889,SUCCESS
    150,2015-05-19 14:02:53,603.549,0x0013,0x0013,0,100,0,0,13614,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,377,0,5,0,0,0,5,889,SUCCESS
    151,2015-05-19 14:02:57,607.543,0x0013,0x0013,0,100,0,0,13608,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,381,0,5,0,0,0,5,890,SUCCESS
    152,2015-05-19 14:03:01,611.555,0x0013,0x0013,0,100,0,0,13608,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,385,0,5,0,0,0,5,888,SUCCESS
    153,2015-05-19 14:03:05,615.547,0x0013,0x0013,0,100,0,0,13608,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,389,0,5,0,0,0,5,889,SUCCESS
    154,2015-05-19 14:03:09,619.556,0x0013,0x0013,0,100,0,0,13608,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,393,0,5,0,0,0,5,889,SUCCESS
    155,2015-05-19 14:03:13,623.549,0x0013,0x0013,0,100,0,0,13608,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,397,0,5,0,0,0,5,890,SUCCESS
    156,2015-05-19 14:03:17,627.559,0x0013,0x0013,0,100,0,0,13602,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,401,0,5,0,0,0,5,890,SUCCESS
    157,2015-05-19 14:03:21,631.555,0x0013,0x0013,0,100,0,0,13602,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,405,0,5,0,0,0,5,888,SUCCESS
    158,2015-05-19 14:03:25,635.546,0x0013,0x0013,0,100,0,0,13602,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,409,0,5,0,0,0,5,889,SUCCESS
    159,2015-05-19 14:03:29,639.557,0x0013,0x0013,0,100,0,0,13602,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,413,0,5,0,0,0,5,889,SUCCESS
    160,2015-05-19 14:03:33,643.551,0x0013,0x0013,0,100,0,0,13602,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,417,0,5,0,0,0,5,889,SUCCESS
    161,2015-05-19 14:03:37,647.560,0x0013,0x0013,0,100,0,0,13590,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,421,0,5,0,0,0,5,890,SUCCESS
    162,2015-05-19 14:03:41,651.554,0x0013,0x0013,0,100,0,0,13590,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,425,0,5,0,0,0,5,888,SUCCESS
    163,2015-05-19 14:03:45,655.562,0x0013,0x0013,0,100,0,0,13590,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,429,0,5,0,0,0,5,890,SUCCESS
    164,2015-05-19 14:03:49,659.557,0x0013,0x0013,0,100,0,0,13590,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,433,0,5,0,0,0,5,889,SUCCESS
    165,2015-05-19 14:03:53,663.550,0x0013,0x0013,0,100,0,0,13590,0,0,24.2,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,437,0,5,0,0,0,5,889,SUCCESS
    166,2015-05-19 14:03:57,667.559,0x0013,0x0013,0,100,0,0,13584,0,0,24.3,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,441,0,5,0,0,0,5,890,SUCCESS
    167,2015-05-19 14:04:01,671.555,0x0013,0x0013,0,100,0,0,13584,0,0,24.3,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,445,0,5,0,0,0,5,888,SUCCESS
    168,2015-05-19 14:04:05,675.563,0x0013,0x0013,0,100,0,0,13584,0,0,24.3,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,449,0,5,0,0,0,5,889,SUCCESS
    169,2015-05-19 14:04:09,679.557,0x0013,0x0013,0,100,0,0,13584,0,0,24.3,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,453,0,5,0,0,0,5,889,SUCCESS
    170,2015-05-19 14:04:13,683.565,0x0013,0x0013,0,100,0,0,13584,0,0,24.3,65535,65535,0,0,25.1,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,457,0,5,0,0,0,5,890,SUCCESS
    171,2015-05-19 14:04:17,687.560,0x0013,0x0013,0,100,0,0,13578,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,461,0,5,0,0,0,5,890,SUCCESS
    172,2015-05-19 14:04:21,691.554,0x0013,0x0013,0,100,0,0,13578,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,465,0,5,0,0,0,5,889,SUCCESS
    173,2015-05-19 14:04:25,695.562,0x0013,0x0013,0,100,0,0,13578,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,469,0,5,0,0,0,5,889,SUCCESS
    174,2015-05-19 14:04:29,699.557,0x0013,0x0013,0,100,0,0,13578,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,473,0,5,0,0,0,5,889,SUCCESS
    175,2015-05-19 14:04:33,703.567,0x0013,0x0013,0,100,0,0,13578,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,477,0,6,0,0,0,6,889,SUCCESS
    176,2015-05-19 14:04:37,707.560,0x0013,0x0013,0,100,0,0,13572,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,481,0,6,0,0,0,6,890,SUCCESS
    177,2015-05-19 14:04:41,711.554,0x0013,0x0013,0,100,0,0,13572,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,485,0,6,0,0,0,6,889,SUCCESS
    178,2015-05-19 14:04:45,715.562,0x0013,0x0013,0,100,0,0,13572,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,489,0,6,0,0,0,6,890,SUCCESS
    179,2015-05-19 14:04:49,719.558,0x0013,0x0013,0,100,0,0,13572,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,493,0,6,0,0,0,6,889,SUCCESS
    180,2015-05-19 14:04:53,723.567,0x0013,0x0013,0,100,0,0,13572,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,497,0,6,0,0,0,6,889,SUCCESS
    181,2015-05-19 14:04:57,727.559,0x0013,0x0013,0,100,0,0,13566,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,501,0,6,0,0,0,6,890,SUCCESS
    182,2015-05-19 14:05:01,731.570,0x0013,0x0013,0,100,0,0,13566,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,505,0,6,0,0,0,6,889,SUCCESS
    183,2015-05-19 14:05:05,735.564,0x0013,0x0013,0,100,0,0,13566,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,509,0,6,0,0,0,6,889,SUCCESS
    184,2015-05-19 14:05:09,739.558,0x0013,0x0013,0,100,0,0,13566,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,513,0,6,0,0,0,6,889,SUCCESS
    185,2015-05-19 14:05:13,743.566,0x0013,0x0013,0,100,0,0,13566,0,0,24.3,65535,65535,0,0,25.0,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,517,0,6,0,0,0,6,889,SUCCESS
    186,2015-05-19 14:05:17,747.559,0x0013,0x0013,0,100,0,0,13560,0,0,24.2,65535,65535,0,0,24.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,521,0,6,0,0,0,6,891,SUCCESS
    187,2015-05-19 14:05:21,751.571,0x0013,0x0013,0,100,0,0,13560,0,0,24.2,65535,65535,0,0,24.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,525,0,6,0,0,0,6,889,SUCCESS
    188,2015-05-19 14:05:25,755.564,0x0013,0x0013,0,100,0,0,13560,0,0,24.2,65535,65535,0,0,24.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-14,0,529,0,6,0,0,0,6,889,SUCCESS
    189,2015-05-19 14:05:29,759.573,0x0013,0x0013,0,100,0,0,13560,0,0,24.2,65535,65535,0,0,24.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,533,1,6,0,0,1,6,889,SUCCESS
    190,2015-05-19 14:05:33,763.566,0x0013,0x0013,0,100,0,0,13560,0,0,24.2,65535,65535,0,0,24.9,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,537,1,6,0,0,1,6,890,SUCCESS
    191,2015-05-19 14:05:37,767.561,0x0013,0x0013,0,100,0,0,13554,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,541,1,6,0,0,1,6,890,SUCCESS
    192,2015-05-19 14:05:41,771.571,0x0013,0x0013,0,100,0,0,13554,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,545,1,6,0,0,1,6,888,SUCCESS
    193,2015-05-19 14:05:45,775.563,0x0013,0x0013,0,100,0,0,13554,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,549,1,6,0,0,1,6,889,SUCCESS
    194,2015-05-19 14:05:49,779.574,0x0013,0x0013,0,100,0,0,13554,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,553,1,6,0,0,1,6,889,SUCCESS
    195,2015-05-19 14:05:53,783.567,0x0013,0x0013,0,100,0,0,13554,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,557,1,6,0,0,1,6,890,SUCCESS
    196,2015-05-19 14:05:57,787.575,0x0013,0x0013,0,100,0,0,13548,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,561,1,6,0,0,1,6,891,SUCCESS
    197,2015-05-19 14:06:01,791.570,0x0013,0x0013,0,100,0,0,13548,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,565,1,6,0,0,1,6,889,SUCCESS
    198,2015-05-19 14:06:05,795.563,0x0013,0x0013,0,100,0,0,13548,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,569,1,6,0,0,1,6,890,SUCCESS
    199,2015-05-19 14:06:09,799.574,0x0013,0x0013,0,100,0,0,13548,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,573,1,6,0,0,1,6,889,SUCCESS
    200,2015-05-19 14:06:13,803.568,0x0013,0x0013,0,100,0,0,13548,0,0,24.2,65535,65535,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-15,0,577,1,6,0,0,1,6,888,SUCCESS
    201,2015-05-19 14:06:17,807.577,0x0003,0x0003,0,100,0,0,14226,1769,229,24.2,65535,0,0,419,24.7,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-14,0,1,0,6,0,0,0,6,889,SUCCESS
    202,2015-05-19 14:06:21,811.572,0x0003,0x0003,0,100,0,0,14628,816,406,24.2,65535,0,0,199,24.7,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-12,0,5,-2,6,0,0,-2,6,888,SUCCESS
    203,2015-05-19 14:06:25,815.565,0x0003,0x0003,0,100,0,0,14622,699,484,24.2,65535,0,0,170,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-12,0,9,-2,6,0,0,-2,6,889,SUCCESS
    204,2015-05-19 14:06:29,819.575,0x0003,0x0003,0,100,0,0,14616,638,526,24.2,65535,0,0,155,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-11,0,13,-3,6,0,0,-3,6,888,SUCCESS
    205,2015-05-19 14:06:33,823.568,0x0003,0x0003,0,100,0,0,14610,599,546,24.2,65535,0,0,146,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-10,0,17,-4,6,0,0,-4,6,888,SUCCESS
    206,2015-05-19 14:06:37,827.577,0x0003,0x0003,0,100,0,0,14610,566,553,24.2,65535,0,0,138,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-10,0,21,-4,6,0,0,-4,6,890,SUCCESS
    207,2015-05-19 14:06:41,831.572,0x0003,0x0003,0,100,0,0,14604,519,551,24.2,65535,0,0,126,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,25,-5,6,0,0,-5,6,888,SUCCESS
    208,2015-05-19 14:06:45,835.580,0x0013,0x0013,0,100,0,0,14484,0,418,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,29,-5,6,0,0,-5,6,888,SUCCESS
    209,2015-05-19 14:06:49,839.574,0x0013,0x0013,0,100,0,0,14484,0,318,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,33,-5,6,0,0,-5,6,889,SUCCESS
    210,2015-05-19 14:06:53,843.568,0x0013,0x0013,0,100,0,0,14484,0,241,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,37,-5,6,0,0,-5,6,889,SUCCESS
    211,2015-05-19 14:06:57,847.577,0x0013,0x0013,0,100,0,0,14484,0,183,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,41,-5,6,0,0,-5,6,890,SUCCESS
    212,2015-05-19 14:07:01,851.571,0x0013,0x0013,0,100,0,0,14484,0,139,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,45,-5,6,0,0,-5,6,889,SUCCESS
    213,2015-05-19 14:07:05,855.580,0x0013,0x0013,0,100,0,0,13662,0,106,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,49,-5,6,0,0,-5,6,888,SUCCESS
    214,2015-05-19 14:07:09,859.578,0x0013,0x0013,0,100,0,0,13662,0,80,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,53,-5,6,0,0,-5,6,886,SUCCESS
    215,2015-05-19 14:07:13,863.584,0x0013,0x0013,0,100,0,0,13662,0,61,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,57,-5,6,0,0,-5,6,889,SUCCESS
    216,2015-05-19 14:07:17,867.576,0x0013,0x0013,0,100,0,0,13662,0,46,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,61,-5,6,0,0,-5,6,890,SUCCESS
    217,2015-05-19 14:07:21,871.571,0x0013,0x0013,0,100,0,0,13662,0,35,24.2,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,65,-5,6,0,0,-5,6,889,SUCCESS
    218,2015-05-19 14:07:25,875.582,0x0013,0x0013,0,100,0,0,13638,0,27,24.1,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,69,-5,6,0,0,-5,6,888,SUCCESS
    219,2015-05-19 14:07:29,879.575,0x0013,0x0013,0,100,0,0,13638,0,20,24.1,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,73,-5,6,0,0,-5,6,889,SUCCESS
    220,2015-05-19 14:07:33,883.583,0x0013,0x0013,0,100,0,0,13638,0,15,24.1,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,77,-5,6,0,0,-5,6,889,SUCCESS
    221,2015-05-19 14:07:37,887.576,0x0013,0x0013,0,100,0,0,13638,0,12,24.1,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x0400,2,4,0,0,-9,0,81,-5,6,0,0,-5,6,891,SUCCESS
    222,2015-05-19 14:07:41,891.587,0x0013,0x0013,0,100,0,0,13638,0,9,24.1,65535,0,0,0,24.8,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,0,-5,6,0,0,-5,6,889,SUCCESS
    223,2015-05-19 14:07:45,895.582,0x0013,0x0013,0,100,0,0,13626,0,7,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,4,-5,6,0,0,-5,6,888,SUCCESS
    224,2015-05-19 14:07:49,899.574,0x0013,0x0013,0,100,0,0,13626,0,5,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,8,-5,6,0,0,-5,6,889,SUCCESS
    225,2015-05-19 14:07:53,903.583,0x0013,0x0013,0,100,0,0,13626,0,4,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,12,-5,6,0,0,-5,6,890,SUCCESS
    226,2015-05-19 14:07:57,907.578,0x0013,0x0013,0,100,0,0,13626,0,3,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,16,-5,6,0,0,-5,6,890,SUCCESS
    227,2015-05-19 14:08:01,911.586,0x0013,0x0013,0,100,0,0,13626,0,2,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,20,-5,6,0,0,-5,6,891,SUCCESS
    228,2015-05-19 14:08:05,915.580,0x0013,0x0013,0,100,0,0,13614,0,2,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,24,-5,6,0,0,-5,6,889,SUCCESS
    229,2015-05-19 14:08:09,919.575,0x0013,0x0013,0,100,0,0,13614,0,1,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,28,-5,6,0,0,-5,6,889,SUCCESS
    230,2015-05-19 14:08:13,923.584,0x0013,0x0013,0,100,0,0,13614,0,1,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,32,-5,6,0,0,-5,6,889,SUCCESS
    231,2015-05-19 14:08:17,927.578,0x0013,0x0013,0,100,0,0,13614,0,1,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,36,-5,7,0,0,-5,7,890,SUCCESS
    232,2015-05-19 14:08:21,931.587,0x0013,0x0013,0,100,0,0,13614,0,1,24.1,65535,0,0,0,24.7,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,40,-5,7,0,0,-5,7,889,SUCCESS
    233,2015-05-19 14:08:25,935.580,0x0013,0x0013,0,100,0,0,13608,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,44,-5,7,0,0,-5,7,890,SUCCESS
    234,2015-05-19 14:08:29,939.591,0x0013,0x0013,0,100,0,0,13608,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,48,-5,7,0,0,-5,7,889,SUCCESS
    235,2015-05-19 14:08:33,943.584,0x0013,0x0013,0,100,0,0,13608,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,52,-5,7,0,0,-5,7,889,SUCCESS
    236,2015-05-19 14:08:37,947.577,0x0013,0x0013,0,100,0,0,13608,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,56,-5,7,0,0,-5,7,890,SUCCESS
    237,2015-05-19 14:08:41,951.588,0x0013,0x0013,0,100,0,0,13608,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,60,-5,7,0,0,-5,7,889,SUCCESS
    238,2015-05-19 14:08:45,955.582,0x0013,0x0013,0,100,0,0,13602,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,64,-5,7,0,0,-5,7,888,SUCCESS
    239,2015-05-19 14:08:50,960.074,0x0013,0x0013,0,100,0,0,13602,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,68,-5,7,0,0,-5,7,889,SUCCESS
    240,2015-05-19 14:08:53,963.584,0x0013,0x0013,0,100,0,0,13602,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,72,-5,7,0,0,-5,7,889,SUCCESS
    241,2015-05-19 14:08:57,967.593,0x0013,0x0013,0,100,0,0,13602,0,0,24.1,65535,65535,0,0,24.6,18,5,14580,10000,0x09E1,0x1116,0x2400,2,4,0,0,-9,0,76,-5,7,0,0,-5,7,891,SUCCESS
    * File created Tue May 19 14:18:42 2015
    * Device Number 100
    * Field Order: Class name, Subclass name, Parameter name, Parameter Value, Units
    Configuration,Safety,OT Chg,55.0,1degC
    Configuration,Safety,OT Chg Time,6,Seconds
    Configuration,Safety,OT Chg Recovery,50.0,1degC
    Configuration,Safety,OT Dsg,60.0,1degC
    Configuration,Safety,OT Dsg Time,2,Seconds
    Configuration,Safety,OT Dsg Recovery,55.0,1degC
    Configuration,Charge Inhibit Cfg,Chg Inhibit Temp Low,0,1degC
    Configuration,Charge Inhibit Cfg,Chg Inhibit Temp High,45.0,1degC
    Configuration,Charge Inhibit Cfg,Temp Hys,5.0,1degC
    Configuration,Charge,Suspend Low Temp,-5.0,1degC
    Configuration,Charge,Suspend High Temp,55.0,1degC
    Configuration,Charge,Pb EFF Efficiency,100,%
    Configuration,Charge,Pb Temp Comp,24.960,%
    Configuration,Charge,Pb Drop Off Percent,96,%
    Configuration,Charge,Pb Reduction Rate,10.000,%
    Configuration,Charge Termination,Taper Current,800,mAmp
    Configuration,Charge Termination,Min Taper Capacity,5,mAmpHr
    Configuration,Charge Termination,Cell Taper Voltage,200,mVolt
    Configuration,Charge Termination,Current Taper Window,40,Seconds
    Configuration,Charge Termination,TCA Set %,99,Percent
    Configuration,Charge Termination,TCA Clear %,95,Percent
    Configuration,Charge Termination,FC Set %,-1,Percent
    Configuration,Charge Termination,FC Clear %,95,Percent
    Configuration,Charge Termination,DODatEOC Delta T,10.0,1degC
    Configuration,Charge Termination,NiMH Delta Temp,3.0,1degC
    Configuration,Charge Termination,NiMH Delta Temp Time,180,Seconds
    Configuration,Charge Termination,NiMH Hold Off  Time,100,Seconds
    Configuration,Charge Termination,NiMH Hold Off Current,240,mAmp
    Configuration,Charge Termination,NiMH Hold Off  Temp,25.0,1degC
    Configuration,Charge Termination,NiMH Cell Negative Delta Volt,17,mVolt
    Configuration,Charge Termination,NiMH Cell Negative Delta Time,16,Seconds
    Configuration,Charge Termination,NiMH Cell Neg Delta Qual Volt,4200,mVolt
    Configuration,Data,Manufacture Date,1980-1-1,Day + Mo*32 + (Yr -1980)*256
    Configuration,Data,Serial Number,0200,hex
    Configuration,Data,Cycle Count,18,Count
    Configuration,Data,CC Threshold,2948,mAmpHr
    Configuration,Data,Max Error Limit,100,%
    Configuration,Data,Design Capacity,20000,MilliAmpHour
    Configuration,Data,Design Energy,24000,MilliWattHour
    Configuration,Data,SOH Load I,-400,MilliAmp
    Configuration,Data,Cell Charge Voltage T1-T2,2430,mV
    Configuration,Data,Cell Charge Voltage T2-T3,2430,mV
    Configuration,Data,Cell Charge Voltage T3-T4,2430,mV
    Configuration,Data,Charge Current T1-T2,10,Percent
    Configuration,Data,Charge Current  T2-T3,50,Percent
    Configuration,Data,Charge Current  T3-T4,30,Percent
    Configuration,Data,JEITA T1,-40,degC
    Configuration,Data,JEITA T2,-10,degC
    Configuration,Data,JEITA T3,50,degC
    Configuration,Data,JEITA T4,85,degC
    Configuration,Data,Design Energy Scale,10,Number
    Configuration,Data,Device Name,bq34z100-G1,-
    Configuration,Data,Manufacturer Name,Texas Inst.,-
    Configuration,Data,Device Chemistry,PB,-
    Configuration,Discharge,SOC1 Set Threshold,150,mAh
    Configuration,Discharge,SOC1 Clear Threshold,175,mAh
    Configuration,Discharge,SOCF Set Threshold,75,mAh
    Configuration,Discharge,SOCF Clear Threshold,100,mAh
    Configuration,Discharge,Cell BL Set Volt Threshold,2800,mVolt
    Configuration,Discharge,Cell BL Set Volt Time,2,Seconds
    Configuration,Discharge,Cell BL Clear Volt Threshold,2900,mVolt
    Configuration,Discharge,Cell BH Set Volt Threshold,4300,mVolt
    Configuration,Discharge,Cell BH Volt Time,2,Seconds
    Configuration,Discharge,Cell BH  Clear Volt Threshold,4200,mVolt
    Configuration,Discharge,Cycle Delta,0.05,%
    Configuration,Manufacturer Data,Pack Lot Code,0000,hex
    Configuration,Manufacturer Data,PCB Lot Code,0000,hex
    Configuration,Manufacturer Data,Firmware Version,0000,hex
    Configuration,Manufacturer Data,Hardware Revision,0000,hex
    Configuration,Manufacturer Data,Cell Revision,0000,hex
    Configuration,Manufacturer Data,DF Config Version,0000,hex
    Configuration,Lifetime Data,Lifetime Max Temp,85.0,1degC
    Configuration,Lifetime Data,Lifetime Min Temp,-40.0,1degC
    Configuration,Lifetime Data,Lifetime Max Chg Current,1791,mAmp
    Configuration,Lifetime Data,Lifetime Max Dsg Current,-4708,mA
    Configuration,Lifetime Data,Lifetime Max Pack Voltage,800,20mV
    Configuration,Lifetime Data,Lifetime Min Pack Voltage,500,20mV
    Configuration,Lifetime Temp Samples,LT Flash Cnt,3,Count
    Configuration,Registers,Pack Configuration,09e1,flags
    Configuration,Registers,Pack Configuration B,ae,flags
    Configuration,Registers,Pack Configuration C,37,flags
    Configuration,Registers,LED_Comm Configuration,00,flags
    Configuration,Registers,Alert Configuration,0000,flags
    Configuration,Registers,Number of series cell,6,num
    Configuration,Lifetime Resolution,LT Temp Res,1.0,1degC
    Configuration,Lifetime Resolution,LT Cur Res,100,mA
    Configuration,Lifetime Resolution,LT V Res,1,20mV
    Configuration,Lifetime Resolution,LT Update Time,60,Seconds
    Configuration,LED Display,LED Hold Time,4,Num
    Configuration,Power,Flash Update OK Cell Volt,1600,mVolt
    Configuration,Power,Sleep Current,10,mAmp
    Configuration,Power,FS Wait,0,Seconds
    System Data,Manufacturer Info,Block A 0,00,hex
    System Data,Manufacturer Info,Block A 1,00,hex
    System Data,Manufacturer Info,Block A 2,00,hex
    System Data,Manufacturer Info,Block A 3,00,hex
    System Data,Manufacturer Info,Block A 4,00,hex
    System Data,Manufacturer Info,Block A 5,00,hex
    System Data,Manufacturer Info,Block A 6,00,hex
    System Data,Manufacturer Info,Block A 7,00,hex
    System Data,Manufacturer Info,Block A 8,00,hex
    System Data,Manufacturer Info,Block A 9,00,hex
    System Data,Manufacturer Info,Block A 10,00,hex
    System Data,Manufacturer Info,Block A 11,00,hex
    System Data,Manufacturer Info,Block A 12,00,hex
    System Data,Manufacturer Info,Block A 13,00,hex
    System Data,Manufacturer Info,Block A 14,00,hex
    System Data,Manufacturer Info,Block A 15,00,hex
    System Data,Manufacturer Info,Block A 16,00,hex
    System Data,Manufacturer Info,Block A 17,00,hex
    System Data,Manufacturer Info,Block A 18,00,hex
    System Data,Manufacturer Info,Block A 19,00,hex
    System Data,Manufacturer Info,Block A 20,00,hex
    System Data,Manufacturer Info,Block A 21,00,hex
    System Data,Manufacturer Info,Block A 22,00,hex
    System Data,Manufacturer Info,Block A 23,00,hex
    System Data,Manufacturer Info,Block A 24,00,hex
    System Data,Manufacturer Info,Block A 25,00,hex
    System Data,Manufacturer Info,Block A 26,00,hex
    System Data,Manufacturer Info,Block A 27,00,hex
    System Data,Manufacturer Info,Block A 28,00,hex
    System Data,Manufacturer Info,Block A 29,00,hex
    System Data,Manufacturer Info,Block A 30,00,hex
    System Data,Manufacturer Info,Block A 31,00,hex
    Gas Gauging,IT Cfg,Load Select,3,Number
    Gas Gauging,IT Cfg,Load Mode,0,Number
    Gas Gauging,IT Cfg,Res Current,10,mAmp
    Gas Gauging,IT Cfg,Max Res Factor,50,num
    Gas Gauging,IT Cfg,Min Res Factor,1,num
    Gas Gauging,IT Cfg,Ra Filter,500,num
    Gas Gauging,IT Cfg,Min PassedChg NiMH-LA 1st Qmax,50,%
    Gas Gauging,IT Cfg,Maximum Qmax Change,100,%
    Gas Gauging,IT Cfg,Cell Terminate Voltage,1750,mVolt
    Gas Gauging,IT Cfg,Cell Term V Delta,100,mVolt
    Gas Gauging,IT Cfg,ResRelax Time,500,Seconds
    Gas Gauging,IT Cfg,User Rate-mA,0,MilliAmp
    Gas Gauging,IT Cfg,User Rate-Pwr,360,mW/cW
    Gas Gauging,IT Cfg,Reserve Cap-mAh,1000,MilliAmpHour
    Gas Gauging,IT Cfg,Reserve Energy,1200,mWh/cWh
    Gas Gauging,IT Cfg,Max Scale Back Grid,4,num
    Gas Gauging,IT Cfg,Cell Min DeltaV,0,mVolt
    Gas Gauging,IT Cfg,Ra Max Delta,15,%
    Gas Gauging,IT Cfg,Design Resistance,42,mOhms
    Gas Gauging,IT Cfg,Reference Grid,4,-
    Gas Gauging,IT Cfg,Qmax Max Delta %,10,mAmpHour
    Gas Gauging,IT Cfg,Max Res Scale,32000,Num
    Gas Gauging,IT Cfg,Min Res Scale,1,Num
    Gas Gauging,IT Cfg,Fast Scale Start SOC,10,%
    Gas Gauging,IT Cfg,Charge Hys V Shift,40,mVolt
    Gas Gauging,IT Cfg,Smooth Relax Time,1000,s
    Gas Gauging,Current Thresholds,Dsg Current Threshold,60,mAmp
    Gas Gauging,Current Thresholds,Chg Current Threshold,75,mAmp
    Gas Gauging,Current Thresholds,Quit Current,40,mAmp
    Gas Gauging,Current Thresholds,Dsg Relax Time,60,Seconds
    Gas Gauging,Current Thresholds,Chg Relax Time,60,Seconds
    Gas Gauging,Current Thresholds,Cell Max IR Correct,400,mV
    Gas Gauging,State,Qmax Cell 0,1000,mAmpHr
    Gas Gauging,State,Cycle Count,0,num
    Gas Gauging,State,Update Status,04,num
    Gas Gauging,State,Cell V at Chg Term,2413,mVolt
    Gas Gauging,State,Avg I Last Run,-299,mAmp
    Gas Gauging,State,Avg P Last Run,-1131,MilliWattHour
    Gas Gauging,State,Cell Delta Voltage,2,mVolt
    Gas Gauging,State,T Rise,2,Num
    Gas Gauging,State,T Time Constant,1000,Num
    Ra Tables,Ra0 Table,Ra Flag,ff55,Hex
    Ra Tables,Ra0 Table,Ra 0,34,Num
    Ra Tables,Ra0 Table,Ra 1,31,Num
    Ra Tables,Ra0 Table,Ra 2,28,Num
    Ra Tables,Ra0 Table,Ra 3,24,Num
    Ra Tables,Ra0 Table,Ra 4,23,Num
    Ra Tables,Ra0 Table,Ra 5,23,Num
    Ra Tables,Ra0 Table,Ra 6,23,Num
    Ra Tables,Ra0 Table,Ra 7,25,Num
    Ra Tables,Ra0 Table,Ra 8,27,Num
    Ra Tables,Ra0 Table,Ra 9,30,Num
    Ra Tables,Ra0 Table,Ra 10,35,Num
    Ra Tables,Ra0 Table,Ra 11,45,Num
    Ra Tables,Ra0 Table,Ra 12,121,Num
    Ra Tables,Ra0 Table,Ra 13,268,Num
    Ra Tables,Ra0 Table,Ra 14,429,Num
    Ra Tables,Ra0x Table,Ra Flag,ffff,Hex
    Ra Tables,Ra0x Table,Ra 0,34,Num
    Ra Tables,Ra0x Table,Ra 1,31,Num
    Ra Tables,Ra0x Table,Ra 2,28,Num
    Ra Tables,Ra0x Table,Ra 3,24,Num
    Ra Tables,Ra0x Table,Ra 4,23,Num
    Ra Tables,Ra0x Table,Ra 5,23,Num
    Ra Tables,Ra0x Table,Ra 6,23,Num
    Ra Tables,Ra0x Table,Ra 7,25,Num
    Ra Tables,Ra0x Table,Ra 8,27,Num
    Ra Tables,Ra0x Table,Ra 9,30,Num
    Ra Tables,Ra0x Table,Ra 10,35,Num
    Ra Tables,Ra0x Table,Ra 11,45,Num
    Ra Tables,Ra0x Table,Ra 12,121,Num
    Ra Tables,Ra0x Table,Ra 13,268,Num
    Ra Tables,Ra0x Table,Ra 14,429,Num
    Calibration,Data,CC Gain,10.158,mohm
    Calibration,Data,CC Delta,10.137,mohm
    Calibration,Data,CC Offset,-1455,num
    Calibration,Data,Board Offset,26,num
    Calibration,Data,Int Temp Offset,0,degC
    Calibration,Data,Ext Temp Offset,0,degC
    Calibration,Data,Voltage Divider,18036,mVolt
    Calibration,Current,Deadband,5,mAmp
    Security,Codes,Sealed to Unsealed,36720414,hex
    Security,Codes,Unsealed to Full,ffffffff,hex
    Security,Codes,Authen Key3,01234567,hex
    Security,Codes,Authen Key2,89abcdef,hex
    Security,Codes,Authen Key1,fedcba98,hex
    Security,Codes,Authen Key0,76543210,hex
  • Martin,
    It looks like the FC bit may not have set, because the charge current was not present for two Current Taper Windows after reaching the Taper Current. Can you send a discharge log and I can check a few other things.
    Tom
  • Tue May 19 16:20:13 EDT 2015
    1,2015-05-19 16:20:18,4.470,0x0013,0x0013,0,100,0,0,13584,0,0,24.2,65535,65535,0,0,26.3,18,5,14580,10000,0x09E1,0x1116,0x2400,0,4,0,0,50,0,101,-64,2,0,0,-106,2,889,SUCCESS
    2,2015-05-19 16:20:22,8.479,0x0003,0x0003,0,100,0,0,13926,1786,119,24.2,65535,0,0,415,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-13,0,1,-1,0,0,0,-107,2,888,SUCCESS
    3,2015-05-19 16:20:26,12.472,0x0003,0x0003,0,100,0,0,14124,1783,519,24.2,65535,0,0,420,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-11,0,5,-3,0,0,0,-109,2,890,SUCCESS
    4,2015-05-19 16:20:30,16.483,0x0003,0x0003,0,100,0,0,14370,1764,821,24.2,65535,0,0,422,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-9,0,9,-5,0,0,0,-111,2,888,SUCCESS
    5,2015-05-19 16:20:34,20.477,0x0003,0x0003,0,100,0,0,14520,1508,1009,24.2,65535,0,0,365,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-8,0,13,-6,0,0,0,-112,2,888,SUCCESS
    6,2015-05-19 16:20:38,24.484,0x0003,0x0003,0,100,0,0,14514,1339,1102,24.2,65535,0,0,324,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-6,0,17,-8,0,0,0,-114,2,890,SUCCESS
    7,2015-05-19 16:20:42,28.478,0x0003,0x0003,0,100,0,0,14496,1218,1139,24.2,65535,0,0,294,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-5,0,21,-9,1,0,0,-115,3,890,SUCCESS
    8,2015-05-19 16:20:46,32.474,0x0003,0x0003,0,100,0,0,14484,1124,1143,24.2,65535,0,0,271,26.1,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-4,0,25,-10,1,0,0,-116,3,888,SUCCESS
    9,2015-05-19 16:20:50,36.484,0x0003,0x0003,0,100,0,0,14478,1051,1126,24.2,65535,0,0,254,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-2,0,29,-12,1,0,0,-118,3,887,SUCCESS
    10,2015-05-19 16:20:54,40.475,0x0003,0x0003,0,100,0,0,14478,988,1098,24.2,65535,0,0,238,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-1,0,33,-13,1,0,0,-119,3,889,SUCCESS
    11,2015-05-19 16:20:58,44.485,0x0003,0x0003,0,100,0,0,14472,934,1063,24.3,65535,0,0,225,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,0,0,37,-14,1,0,0,-120,3,890,SUCCESS
    12,2015-05-19 16:21:02,48.480,0x0003,0x0003,0,100,0,0,14472,887,1025,24.3,65535,0,0,214,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,1,0,41,-15,1,0,0,-121,3,889,SUCCESS
    13,2015-05-19 16:21:06,52.490,0x0003,0x0003,0,100,0,0,14466,842,984,24.3,65535,0,0,203,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,2,0,45,-16,1,0,0,-122,3,887,SUCCESS
    14,2015-05-19 16:21:10,56.482,0x0003,0x0003,0,100,0,0,14466,804,944,24.3,65535,0,0,194,26.1,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,3,0,49,-17,1,0,0,-123,3,889,SUCCESS
    15,2015-05-19 16:21:14,60.477,0x0003,0x0003,0,100,0,0,14460,772,906,24.3,65535,0,0,186,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,3,0,53,-17,1,0,0,-123,3,889,SUCCESS
    16,2015-05-19 16:21:18,64.485,0x0003,0x0003,0,100,0,0,14460,745,869,24.3,65535,0,0,180,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,4,0,57,-18,1,0,0,-124,3,891,SUCCESS
    17,2015-05-19 16:21:22,68.481,0x0003,0x0003,0,100,0,0,14460,717,835,24.3,65535,0,0,173,26.2,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,5,0,61,-19,1,0,0,-125,3,888,SUCCESS
    18,2015-05-19 16:21:26,72.489,0x0003,0x0003,0,100,0,0,14466,694,803,24.3,65535,0,0,167,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,6,0,65,-20,1,0,0,-126,3,888,SUCCESS
    19,2015-05-19 16:21:30,76.482,0x0003,0x0003,0,100,0,0,14466,677,774,24.3,65535,0,0,163,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,7,0,69,-21,1,0,0,-127,3,890,SUCCESS
    20,2015-05-19 16:21:34,80.478,0x0003,0x0003,0,100,0,0,14460,660,748,24.3,65535,0,0,159,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,7,0,73,-21,1,0,0,-127,3,888,SUCCESS
    21,2015-05-19 16:21:39,85.576,0x0003,0x0003,0,100,0,0,14466,643,719,24.3,65535,0,0,155,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,8,0,78,-22,1,0,0,-128,3,892,SUCCESS
    22,2015-05-19 16:21:43,90.006,0x0003,0x0003,0,100,0,0,14466,627,695,24.3,65535,0,0,151,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,9,0,82,-23,1,0,0,-129,3,892,SUCCESS
    23,2015-05-19 16:21:46,92.489,0x0003,0x0003,0,100,0,0,14466,623,686,24.3,65535,0,0,150,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,9,0,85,-24,1,0,0,-130,3,889,SUCCESS
    24,2015-05-19 16:21:50,96.483,0x0003,0x0003,0,100,0,0,14466,614,669,24.3,65535,0,0,148,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,10,0,89,-24,1,0,0,-130,3,890,SUCCESS
    25,2015-05-19 16:21:54,100.492,0x0003,0x0003,0,100,0,0,14466,607,655,24.3,65535,0,0,146,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,11,0,93,-25,1,0,0,-131,3,889,SUCCESS
    26,2015-05-19 16:21:58,104.485,0x0003,0x0003,0,100,0,0,14466,600,642,24.3,65535,0,0,145,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,11,0,96,-26,1,0,0,-132,3,890,SUCCESS
    27,2015-05-19 16:22:02,108.480,0x0003,0x0003,0,100,0,0,14466,594,631,24.3,65535,0,0,143,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,12,0,100,-26,1,0,0,-132,3,889,SUCCESS
    28,2015-05-19 16:22:06,112.489,0x0003,0x0003,0,100,0,0,14466,590,622,24.3,65535,0,0,142,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,13,0,104,-27,1,0,0,-133,3,889,SUCCESS
    29,2015-05-19 16:22:10,116.483,0x0003,0x0003,0,100,0,0,14466,586,613,24.3,65535,0,0,141,26.3,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,13,0,108,-27,1,0,0,-133,3,889,SUCCESS
    30,2015-05-19 16:22:14,120.492,0x0003,0x0003,0,100,0,0,14466,580,606,24.3,65535,0,0,140,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,14,0,112,-28,1,0,0,-134,3,889,SUCCESS
    31,2015-05-19 16:22:18,124.486,0x0003,0x0003,0,100,0,0,14466,577,599,24.3,65535,0,0,139,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,15,0,116,-29,1,0,0,-135,3,890,SUCCESS
    32,2015-05-19 16:22:22,128.496,0x0003,0x0003,0,100,0,0,14466,576,594,24.3,65535,0,0,139,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,15,0,120,-29,1,0,0,-135,3,888,SUCCESS
    33,2015-05-19 16:22:26,132.489,0x0003,0x0003,0,100,0,0,14466,573,589,24.3,65535,0,0,138,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,16,0,124,-30,1,0,0,-136,3,888,SUCCESS
    34,2015-05-19 16:22:30,136.483,0x0003,0x0003,0,100,0,0,14466,570,585,24.3,65535,0,0,137,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,17,0,128,-31,1,0,0,-137,3,889,SUCCESS
    35,2015-05-19 16:22:34,140.493,0x0003,0x0003,0,100,0,0,14466,569,581,24.3,65535,0,0,137,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,17,0,132,-31,1,0,0,-137,3,889,SUCCESS
    36,2015-05-19 16:22:38,144.487,0x0003,0x0003,0,100,0,0,14466,567,578,24.4,65535,0,0,137,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,18,0,136,-32,1,0,0,-138,3,889,SUCCESS
    37,2015-05-19 16:22:42,148.496,0x0003,0x0003,0,100,0,0,14466,565,575,24.3,65535,0,0,136,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,18,0,140,-32,1,0,0,-138,3,888,SUCCESS
    38,2015-05-19 16:22:46,152.489,0x0003,0x0003,0,100,0,0,14466,565,573,24.3,65535,0,0,136,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,19,0,144,-33,1,0,0,-139,3,890,SUCCESS
    39,2015-05-19 16:22:50,156.500,0x0003,0x0003,0,100,0,0,14466,562,570,24.3,65535,0,0,135,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,20,0,148,-34,1,0,0,-140,3,889,SUCCESS
    40,2015-05-19 16:22:54,160.493,0x0003,0x0003,0,100,0,0,14466,561,568,24.3,65535,0,0,135,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,20,0,152,-34,1,0,0,-140,3,889,SUCCESS
    41,2015-05-19 16:22:58,164.532,0x0003,0x0003,0,100,0,0,14466,562,567,24.3,65535,0,0,135,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-14,0,156,0,0,0,0,-141,3,890,SUCCESS
    42,2015-05-19 16:23:02,168.496,0x0003,0x0003,0,100,0,0,14466,561,565,24.4,65535,0,0,135,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-13,0,160,-1,0,0,0,-142,3,889,SUCCESS
    43,2015-05-19 16:23:06,172.490,0x0003,0x0003,0,100,0,0,14466,560,564,24.4,65535,0,0,135,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-13,0,164,-1,0,0,0,-142,3,889,SUCCESS
    44,2015-05-19 16:23:10,176.500,0x0003,0x0003,0,100,0,0,14466,557,562,24.4,65535,0,0,134,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-12,0,168,-2,0,0,0,-143,3,889,SUCCESS
    45,2015-05-19 16:23:14,180.493,0x0003,0x0003,0,100,0,0,14466,557,561,24.4,65535,0,0,134,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-12,0,172,-2,0,0,0,-143,3,888,SUCCESS
    46,2015-05-19 16:23:18,184.923,0x0003,0x0003,0,100,0,0,14466,556,560,24.4,65535,0,0,135,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-11,0,177,-3,0,0,0,-144,3,890,SUCCESS
    47,2015-05-19 16:23:23,189.588,0x0003,0x0003,0,100,0,0,14466,555,559,24.4,65535,0,0,134,26.4,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-10,0,181,-4,0,0,0,-145,3,890,SUCCESS
    48,2015-05-19 16:23:27,194.017,0x0003,0x0003,0,100,0,0,14466,556,558,24.4,65535,0,0,134,26.5,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-9,0,186,-5,0,0,0,-146,3,891,SUCCESS
    49,2015-05-19 16:23:31,197.358,0x0003,0x0003,0,100,0,0,14466,554,557,24.4,65535,0,0,134,26.5,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-9,0,189,-5,0,0,0,-146,3,888,SUCCESS
    50,2015-05-19 16:23:35,201.786,0x0003,0x0003,0,100,0,0,14466,553,556,24.4,65535,0,0,133,26.5,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-8,0,194,-6,0,0,0,-147,3,891,SUCCESS
    51,2015-05-19 16:23:38,204.502,0x0003,0x0003,0,100,0,0,14466,553,556,24.4,65535,0,0,133,26.5,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-8,0,196,-6,0,0,0,-147,3,890,SUCCESS
    52,2015-05-19 16:23:43,209.586,0x0003,0x0003,0,100,0,0,14466,553,555,24.4,65535,0,0,133,26.5,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-7,0,201,-7,0,0,0,-148,3,891,SUCCESS
    53,2015-05-19 16:23:47,214.016,0x0003,0x0003,0,100,0,0,14466,551,554,24.4,65535,0,0,133,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-6,0,206,-8,0,0,0,-149,3,892,SUCCESS
    54,2015-05-19 16:23:51,217.358,0x0003,0x0003,0,100,0,0,14466,552,553,24.4,65535,0,0,133,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-6,0,209,-8,0,0,0,-149,3,889,SUCCESS
    55,2015-05-19 16:23:55,221.786,0x0003,0x0003,0,100,0,0,14466,550,553,24.4,65535,0,0,133,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-5,0,214,-9,0,0,0,-150,3,891,SUCCESS
    56,2015-05-19 16:23:58,225.128,0x0003,0x0003,0,100,0,0,14466,550,552,24.4,65535,0,0,133,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-5,0,217,-9,0,0,0,-150,3,889,SUCCESS
    57,2015-05-19 16:24:03,229.586,0x0003,0x0003,0,100,0,0,14466,550,551,24.4,65535,0,0,133,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-4,0,221,-10,0,0,0,-151,3,891,SUCCESS
    58,2015-05-19 16:24:06,232.927,0x0003,0x0003,0,100,0,0,14466,549,551,24.4,65535,0,0,132,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-3,0,225,-11,0,0,0,-152,3,889,SUCCESS
    59,2015-05-19 16:24:10,236.500,0x0003,0x0003,0,100,0,0,14466,548,550,24.4,65535,0,0,132,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-3,0,228,-11,0,0,0,-152,3,889,SUCCESS
    60,2015-05-19 16:24:15,242.020,0x0003,0x0003,0,100,0,0,14466,547,550,24.4,65535,0,0,132,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-2,0,234,-12,0,0,0,-153,3,891,SUCCESS
    61,2015-05-19 16:24:19,245.361,0x0003,0x0003,0,100,0,0,14466,548,549,24.4,65535,0,0,132,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-2,0,237,-12,0,0,0,-153,3,889,SUCCESS
    62,2015-05-19 16:24:23,249.790,0x0003,0x0003,0,100,0,0,14466,548,549,24.4,65535,0,0,132,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-1,0,241,-13,0,0,0,-154,3,891,SUCCESS
    63,2015-05-19 16:24:26,252.506,0x0003,0x0003,0,100,0,0,14466,546,548,24.4,65535,0,0,132,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,-1,0,244,-13,0,0,0,-154,3,889,SUCCESS
    64,2015-05-19 16:24:30,256.499,0x0003,0x0003,0,100,0,0,14466,547,548,24.4,65535,0,0,132,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,0,0,248,-14,1,0,0,-155,4,890,SUCCESS
    65,2015-05-19 16:24:34,260.508,0x0003,0x0003,0,100,0,0,14466,546,548,24.4,65535,0,0,132,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,1,0,252,-15,1,0,0,-156,4,890,SUCCESS
    66,2015-05-19 16:24:38,264.503,0x0003,0x0003,0,100,0,0,14466,545,547,24.4,65535,0,0,131,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,1,0,256,-15,1,0,0,-156,4,890,SUCCESS
    67,2015-05-19 16:24:42,268.497,0x0003,0x0003,0,100,0,0,14466,548,547,24.4,65535,0,0,132,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,2,0,260,-16,1,0,0,-157,4,889,SUCCESS
    68,2015-05-19 16:24:46,272.505,0x0003,0x0003,0,100,0,0,14466,544,546,24.4,65535,0,0,131,26.6,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,2,0,264,-16,1,0,0,-157,4,889,SUCCESS
    69,2015-05-19 16:24:50,276.500,0x0003,0x0003,0,100,0,0,14466,546,546,24.4,65535,0,0,132,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,3,0,268,-17,1,0,0,-158,4,889,SUCCESS
    70,2015-05-19 16:24:54,280.510,0x0003,0x0003,0,100,0,0,14466,545,546,24.4,65535,0,0,131,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,4,0,272,-18,1,0,0,-159,4,889,SUCCESS
    71,2015-05-19 16:24:58,284.503,0x0003,0x0003,0,100,0,0,14466,544,545,24.4,65535,0,0,131,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,4,0,276,-18,1,0,0,-159,4,890,SUCCESS
    72,2015-05-19 16:25:02,288.497,0x0003,0x0003,0,100,0,0,14466,544,545,24.4,65535,0,0,131,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,5,0,280,-19,1,0,0,-160,4,889,SUCCESS
    73,2015-05-19 16:25:06,292.505,0x0003,0x0003,0,100,0,0,14466,542,544,24.4,65535,0,0,131,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,6,0,284,-20,1,0,0,-161,4,890,SUCCESS
    74,2015-05-19 16:25:11,297.172,0x0003,0x0003,0,100,0,0,14466,542,544,24.4,65535,0,0,131,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,6,0,289,-20,1,0,0,-161,4,889,SUCCESS
    75,2015-05-19 16:25:14,300.510,0x0003,0x0003,0,100,0,0,14466,544,544,24.4,65535,0,0,131,26.7,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,7,0,292,-21,1,0,0,-162,4,889,SUCCESS
    76,2015-05-19 16:25:18,304.503,0x0003,0x0003,0,100,0,0,14466,543,544,24.4,65535,0,0,131,26.8,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,7,0,296,-21,1,0,0,-162,4,889,SUCCESS
    77,2015-05-19 16:25:22,308.512,0x0003,0x0003,0,100,0,0,14466,542,543,24.4,65535,0,0,131,26.8,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,8,0,300,-22,1,0,0,-163,4,890,SUCCESS
    78,2015-05-19 16:25:26,312.507,0x0003,0x0003,0,100,0,0,14466,542,543,24.4,65535,0,0,131,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,9,0,304,-23,1,0,0,-164,4,889,SUCCESS
    79,2015-05-19 16:25:30,316.501,0x0003,0x0003,0,100,0,0,14466,541,543,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,9,0,308,-23,1,0,0,-164,4,888,SUCCESS
    80,2015-05-19 16:25:35,321.599,0x0003,0x0003,0,100,0,0,14466,541,542,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,10,0,313,-24,1,0,0,-165,4,891,SUCCESS
    81,2015-05-19 16:25:38,324.940,0x0003,0x0003,0,100,0,0,14466,541,542,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,10,0,316,-24,1,0,0,-165,4,890,SUCCESS
    82,2015-05-19 16:25:43,329.604,0x0003,0x0003,0,100,0,0,14466,542,542,24.4,65535,0,0,131,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,11,0,321,-25,1,0,0,-166,4,890,SUCCESS
    83,2015-05-19 16:25:46,332.944,0x0003,0x0003,0,100,0,0,14466,540,542,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,12,0,324,-26,1,0,0,-167,4,888,SUCCESS
    84,2015-05-19 16:25:50,336.516,0x0003,0x0003,0,100,0,0,14466,542,541,24.4,65535,0,0,131,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,12,0,328,-26,1,0,0,-167,4,889,SUCCESS
    85,2015-05-19 16:25:54,340.510,0x0003,0x0003,0,100,0,0,14466,540,541,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,13,0,332,-27,1,0,0,-168,4,889,SUCCESS
    86,2015-05-19 16:25:58,344.505,0x0003,0x0003,0,100,0,0,14466,541,541,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,13,0,336,-27,1,0,0,-168,4,889,SUCCESS
    87,2015-05-19 16:26:02,348.515,0x0003,0x0003,0,100,0,0,14466,540,541,24.4,65535,0,0,130,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,14,0,340,-28,1,0,0,-169,4,888,SUCCESS
    88,2015-05-19 16:26:06,352.506,0x0003,0x0003,0,100,0,0,14466,540,541,24.4,65535,0,0,130,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,15,0,344,-29,1,0,0,-170,4,889,SUCCESS
    89,2015-05-19 16:26:10,356.516,0x0003,0x0003,0,100,0,0,14466,539,540,24.4,65535,0,0,130,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,15,0,348,-29,1,0,0,-170,4,890,SUCCESS
    90,2015-05-19 16:26:14,360.510,0x0003,0x0003,0,100,0,0,14466,538,540,24.4,65535,0,0,130,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,16,0,352,-30,1,0,0,-171,4,890,SUCCESS
    91,2015-05-19 16:26:18,364.943,0x0003,0x0003,0,100,0,0,14466,540,540,24.4,65535,0,0,130,27.1,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,16,0,356,-30,1,0,0,-171,4,887,SUCCESS
    92,2015-05-19 16:26:23,369.603,0x0003,0x0003,0,100,0,0,14466,539,539,24.4,65535,0,0,130,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,17,0,361,-31,1,0,0,-172,4,891,SUCCESS
    93,2015-05-19 16:26:26,372.507,0x0003,0x0003,0,100,0,0,14466,538,539,24.4,65535,0,0,130,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,18,0,364,-32,1,0,0,-173,4,888,SUCCESS
    94,2015-05-19 16:26:30,376.517,0x0003,0x0003,0,100,0,0,14466,540,539,24.4,65535,0,0,130,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,18,0,368,-32,1,0,0,-173,4,889,SUCCESS
    95,2015-05-19 16:26:34,380.510,0x0003,0x0003,0,100,0,0,14466,539,540,24.4,65535,0,0,130,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,19,0,372,-33,1,0,0,-174,4,890,SUCCESS
    96,2015-05-19 16:26:39,385.221,0x0003,0x0003,0,100,0,0,14466,539,540,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,19,0,376,-33,1,0,0,-174,4,890,SUCCESS
    97,2015-05-19 16:26:42,388.561,0x0003,0x0003,0,100,0,0,14466,538,539,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,20,0,380,-34,1,0,0,-175,4,889,SUCCESS
    98,2015-05-19 16:26:46,392.507,0x0003,0x0003,0,100,0,0,14466,538,539,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,21,0,384,-35,1,0,0,-176,4,889,SUCCESS
    99,2015-05-19 16:26:50,396.516,0x0003,0x0003,0,100,0,0,14466,538,539,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,21,0,388,-35,1,0,0,-176,4,889,SUCCESS
    100,2015-05-19 16:26:54,400.510,0x0003,0x0003,0,100,0,0,14466,538,538,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,22,0,392,-36,1,0,0,-177,4,889,SUCCESS
    101,2015-05-19 16:26:58,404.520,0x0003,0x0003,0,100,0,0,14466,539,538,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,22,0,396,-36,1,0,0,-177,4,890,SUCCESS
    102,2015-05-19 16:27:02,408.514,0x0003,0x0003,0,100,0,0,14466,537,538,24.4,65535,0,0,129,27.0,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,23,0,400,-37,1,0,0,-178,4,889,SUCCESS
    103,2015-05-19 16:27:06,412.522,0x0003,0x0003,0,100,0,0,14466,538,538,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,24,0,404,-38,1,0,0,-179,4,888,SUCCESS
    104,2015-05-19 16:27:10,416.517,0x0003,0x0003,0,100,0,0,14466,539,538,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,24,0,408,-38,1,0,0,-179,4,889,SUCCESS
    105,2015-05-19 16:27:14,420.511,0x0003,0x0003,0,100,0,0,14466,538,538,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,25,0,412,-39,1,0,0,-180,4,889,SUCCESS
    106,2015-05-19 16:27:18,424.520,0x0003,0x0003,0,100,0,0,14466,538,538,24.4,65535,0,0,130,26.9,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,25,0,416,-39,1,0,0,-180,4,890,SUCCESS
    107,2015-05-19 16:27:22,428.811,0x0003,0x0003,0,100,0,0,14472,539,538,24.4,65535,0,0,130,26.8,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,26,0,420,-40,1,0,0,-181,4,888,SUCCESS
    108,2015-05-19 16:27:26,432.523,0x0003,0x0003,0,100,0,0,14472,539,538,24.5,65535,0,0,130,26.8,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,26,0,424,-40,1,0,0,-181,4,888,SUCCESS
    109,2015-05-19 16:27:31,437.609,0x0013,0x0013,0,100,0,0,14328,0,393,24.5,65535,0,0,0,26.8,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,26,0,429,-40,1,0,0,-181,4,890,SUCCESS
    110,2015-05-19 16:27:34,440.527,0x0013,0x0013,0,100,0,0,14328,0,320,24.5,65535,0,0,0,26.8,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,26,0,432,-40,1,0,0,-181,4,889,SUCCESS
    111,2015-05-19 16:27:38,444.519,0x0013,0x0013,0,100,0,0,14328,0,243,24.5,65535,0,0,0,26.8,18,5,14580,10000,0x09E1,0x1196,0x0400,0,4,0,0,26,0,436,-40,1,0,0,-181,4,890,SUCCESS
    Hi Tom,
    I have tried what you have suggested already, to extend the charging taper current for two current taper windows but the FC bit is still not getting set.
    Are you referring to a complete battery discharge log? If so, it will take me about a day to create which I will provide to you once it is done.
    Martin
  • Martin,
    I do not see a reason why the gauge would not reach charge termination and set the FC bit. I do see some other issues with the file. The BATHI and BATLOW thresholds are not set properly. Maybe this is causing the FC bit not to set. Qmax should also be set to a value close to the Design Capacity. Please correct these parameters and try again.
    Tom
  • Hi Tom,
    I have done what you have suggested and tried to do the learning cycle twice. Both times, the appropriate flags OCVTAKEN and FC bit get set, VOK turns green, but the Learned status does not increment to 5. There are two log files as my bqstudio crashed. Any suggestions are appreciated.
    Martinmay 26.log
    * Texas Instruments Data Flash File
    * File created Thu May 28 13:44:38 2015
    * Device Number 100
    * Firmware Version 0.16
    * Build Number not available
    * Order Number not available
    * bqz Device Number 100
    * bqz Firmware Version 0.16
    * bqz Build Number 17
    Configuration,Charge Termination,Cell Taper Voltage,500,mVolt
    Configuration,Data,Cycle Count,29,Count
    Configuration,Discharge,Cell BL Set Volt Threshold,1750,mVolt
    Configuration,Discharge,Cell BL Clear Volt Threshold,1810,mVolt
    Configuration,Discharge,Cell BH Set Volt Threshold,2430,mVolt
    Configuration,Discharge,Cell BH  Clear Volt Threshold,2250,mVolt
    Configuration,Lifetime Data,Lifetime Min Pack Voltage,429,20mV
    Configuration,Lifetime Temp Samples,LT Flash Cnt,12,Count
    Gas Gauging,State,Qmax Cell 0,20000,mAmpHr
    Gas Gauging,State,Cell V at Chg Term,2410,mVolt
    Calibration,Data,CC Offset,-1453,num
    may 25.log
  • Martin,
    The Qmax update was disqualified during the discharge. Maybe it had not rested long enough. The VOK flag is not set during discharge, so Qmax will not update. The VOK flag was set during the charge cycle and all of the criteria were in place for a Qmax update, but Qmax cannot update after charge for PbA cells. Also, you should have a continuous charge and discharge and not let the current turn on and off during the cycle.
    I would rerun the cycle, make sure that the OCVTAKEN flag is set during the rest period after charge and make sure that the VOK flag turns on when the discharge begins.
    Tom
  • Hi Tom,
    What flag/register indicates the Qmax update was disqualified during the discharge?
    Also during discharge, how should the voltage bounce be dealt with for PbA cells. From what I can see, I need to bring the voltage down to around 6V, disconnect the load, the battery will recover to around 11V, and then reconnect the load. This needs to be done multiple times to get the battery to near 0 capacity while keeping the discharge above C/10 under load.
    The reason for the non continuous charge and discharge is I cannot leave the equipment unattended while powered overnight. I have ensured the OCVTAKEN and VOK flags gets set accordingly.
    Martin
  • You will not have to worry about the bounce with the -G1 device. The 90% change in DOD requirement was changed to 50%. So, you should be okay as long as you discharge to the termination voltage and allow the pack to rest.
  • Hi Tom,
    Thank you the gauge has learned the battery status . It seems I needed to do an extra charge and discharge cycle in addition to what the steps mentioned.
    I have one more question if we decide to pursue this route. Now that the fuel gauge has a learned status of 6, how do I reset this so I can learn other batteries?
    Martin
  • You do not have to run an extra charge and discharge cycle, but it would be a good idea to check the gauging accuracy.
    To create golden senc file.
    • Export a gg file.
    • Change the Update Status to 02.
    • Change both Cycle Count parameters to 0.
    • Save the file.
    • Load the default senc file.
    • Load the ChemID
    • Load the modified gg file.
    • Export the golden senc file from the I2C Pro screen.
    You can then program this file into other packs, calibrate the pack and the Enable IT. We also recommend that you Seal the pack before it is shipped.
