LMZ34002 Noise Issue
Other Parts Discussed in Thread: LMZ34002
I am currently using the LMZ34002 to invert a +5 DC V supply into a -5 DC V supply.  Upon observing the DC power supply before and after the inverter, there seems to be a small amount of noise injected into the -5 DC V supply.  This noise is affecting the rest of the analog circuitry.
Any ideas whether this is an LMZ34002 issue?  If not, how do you recommend eliminating this noise in our -5 DC V supply?  We already attempted adding bypass capacitors between both DC V supply and ground.  Thank you.
