My input = 24VDC
Output required is : 34V / 1 Ampere
Is there a Power Module with these specs ?
Atul Bhakay
My input = 24VDC
Atul Bhakay
The TPS61175 is a good choice for this application. Its maximum output voltage is 38V and the peak switch current is 3A. But its maximum input voltage is 18V. So you can choose a LDO to step down the voltage from 24V to 15-18V, then connect the LDO's output to the TPS61175's input.
Helen
You're welcom.
Could you share the detailed application information for us? Like in what kind of equipment?
