1. Is it safe for the power supply to work the way I have described above (in almost the short-circuit mode in the very beginning of the charging process)?
2. Are we right to suppose that the initial current peak appears because of some delay in the LM317MDCY current protection circuit? Is there any way to eliminate this delay?
3. How high can be the real value of the initial current (measured by the wide-bandwidth current probe we do not have)?
4. Is there any simple way to introduce the “soft-start” in the LM317MDCY power supply (or in any other TI LDO power supply with similar characteristics)?
5. As a temporary solution, we tried to limit the charge current by a small-value resistor in series with the diode. This totally eliminates the initial current peak but substantially increases the charging time. Is this a good solution of the problem, or do you have a better one?
31473 - Kinder care
