TPS40170 M/S pin at Master mode
Hi
Is it possible to be left the M/S pin open at master mode if the sync function is not used?
I know you recommend to put into slave mode if the sync function is not used.
However our customer would like share this device with other board which is used at master mode with sync function. They would like to reduce the cost modifing the layout.
Koji Hamamoto
