About reverse current protection for TPS22967/TPS22958
Other Parts Discussed in Thread: TPS22967, TPS22958, TPS22953
I have a question about TPS22967/TPS22958.
Conditions  Vin < Vout,
Does This device support reverse current protection when switch is Off.
(In this device off,Does the device current flow Out to IN. )
  • Hi Ozawa,
    The TPS22967 and TPS22958 do not have any reverse current protection when the switch is off.  If VOUT > VIN, then reverse current will flow through the device (from OUT to IN).
    If you are looking for a device in a plastic package which has reverse current protection, then you may want to take a look at the TPS22953.  This device is similar to the TPS22967 but features reverse current protection and has a power good pin which can act as an indicator to tell when VOUT has risen to its final value.
    Let me know if you have any further questions.
    Alek Kaknevicius
