TPS65721 BATTERY PACK TEMPERATURE MONITORING
Other Parts Discussed in Thread: TPS65721
Hi
I found TERN_EN(CHGCONFIG0) need to set as ‘0’, the interrupt can work.
but this behavior is not the same described in TI’s TPS65721 spec (BATTERY PACK TEMPERATURE MONITORING section).
Could you help to confirm the usage of TERN_EN in CHGCONFIG0 ? It seems that TS pin monitoring is disabled if TERN_EN = 1.
thanks.
  • By what do you mean the interrupt can work? If TERM_EN = 0 then the charger goes into CV mode and stays in CV mode until disconnected or disabled. Please find the CHARGE TERMINATION ON/OFF section of the datasheet for further information on the use of this bit.
