BQ24780S-EVM VSYS powing issue
Currently received the evaluation board for testing on performance for use in our design, yet while I hooked up all the equipment required to test per the user guide the VSYS connection is causing the ACOK led to become dim and pulse. With no load on VSYS, the system works fine. The input MOSFETS for the adapter seem to be working fine, yet Q3, Q4, and Q5 during diode testing to short for a few seconds before forward voltage is read. Is this normal per the layout for the eval board?
