TLC5955 SPI usage
Other Parts Discussed in Thread: TLC5955
I am trying to drive 256 RGB leds using TLC5955. So I would need 16 drivers. I was thinking of a few architectures. Can you please let me know if they are good enough?
So the question is can I use the same SPI lines to drive another chain of devices controlled by separate latch line as shown below. Or should I use a different set of SPI lines to control the 2nd set of devices.
So to simplify, can I use the SPI bus controlling the TLV to talk to other SPI slave devices on the board?
Nikhil
