Hi
Our customer is evaluating LMR16006. Because this device is small and easy to use.
They would like to know about current limit operation and limit value.
1. How does this device control the current limit? Can we set the current limit value by external component?
We understand the current is compared with internal COMP voltage at each cycle.
The current limit protection works (= turn off the high side FET) if the peak current voltage is crossed the COMP voltage.
2. Could you provide the minimum of current limit (= Peak current limit : Ilimit)?
3. What does Peak current limit mean?
This current means the current of high side switch. This mean that this peak current is depends on VIn and Inductor.
On the datasheet there is the Peak current limit. Is there any condition? (Vin and Inductor)
Koji Hamamoto
