TPS65218 / to reset FSEAL bit
Guru 29720 points
Hi Team,
The datasheet shows as the following to reset FSEAL bit.
(datasheet page.42)
Coin-cell battery and main supply must be disconnected from the IC to reset the FSEAL bit again.
Could you tell me the threshold voltage of coin-cell battery and main supply to reset FSEAL bit?
Does it need to  voltage to 0V each?
My customer confirmed FSEAL bit didn't be reset when discharged as much as 0.7V each.
Yaita / Japan disty
