I am working to develop a circuit which will speed up the turn-off time of a LM5069 IC, which is being used to drive 4x parallel NFETs. My working solution is to use a signal NFET and pull the GATE node directly to GND. The "....kill" signal is used to rapidly terminate current flow.
Is there a potential to damage the IC (particularly the charge pump) by doing this? Should I limit the current to GND, and if so, to what amount?
I've attached a partial schematic which shows the circuit referenced.
Lucas
