Using UCC28051 as a sub for ST Micro part # L6562A
Hello:
My customer is currently using an ST Micro "Transition Mode PFC Controller" part # L6562A and we are finding that some of the finished product has a high THD that is causing us to reject the finished product.  When we change this part, it solves the high THD issue.  When I called ST Micro, they told me it was a known design issue and that there is no plan to fix the problem.  Therefore I need to find a replacement part.
In my search I came across your part # UCC28051D and it looks like an excellent substitution for the ST Micro part.  Am I correct in this assumption?  I compared pin outs and specs for both parts and it seems to me your part is a direct sub.  In fact, the Simplified Application Diagram on page 1 of the datasheet matches almost exactly the curent schematic for the ST Micro part.  I am attaching the current schematic for the assembly I am building.  It is used to drive an 18 LED panel used by the US Navy.  I will be ordering 37,500 pcs a year at the current run rate.
I need to make a decision soon as I am scheduled to begin building 12,000 more assemblies with whatever substitute I can find.  Any help would be appreciated.MPS1117B_SCH.pdf
Thank You.
Thomas DeGasperi
  • Hi Thomas,
    The UCC28051D is pin for pin compatible with the ST L6562A and the parts are pretty much functionally equivalent.
    However there are significant differences in the electrical characteristic tables that may or may not be important to your design.
    You will need to compare all IC parameters and see which is important to your design and adjust circuit component values if necessary.
    I don't know what causes the THD issue in your original design but you should try to get more details on what was going on here.
    Usually you can adjust some circuit value to improve THD.
    John Griffin
