Considering the case that the Vbat is below 2.9V, the chip should regulate the voltage in the OUT pin between 3.4 up to 3.6V. Anybody knows what's the máximum current that the BQ24050 may supply at the OUT pin?. Of course, the idea is also charge the battery at a programmed current. What's the ratio between the current output at the OUT pin and the charge current?.
Joel
