Power dissipation for TPS9264/41
Other Parts Discussed in Thread: TPS92640, TPS92641
I am considering using the TPS92640 (or the TPS92641 if I need better PWM performance) for a high power led application.
How can I calculate the total power dissipation in the IC given Vin, Vout, fsw and data for the FETs?
/Ruben
  • The power dissipation in the IC can be closely approximated by using the following:
    1. Quiescent current dissipation: P(Q) = IQ * Vin
    2. VCC current dissipation: P(VCC) = I(VCC) * Vin
    4. I(VCC) = 2 * Qg(total) * fsw (the factor of 2 assumes the same FET for both high and low side, otherwise calcluate I(VCC) for each and add them)
    3. P(total) = P(Q) + P(VCC)
    Those are the majority losses in the IC, there will be some additional but they will be a small percentage of those above.
