TPS65023 unused LDOs, DEFLDOx termination
We are using TPS60523B in our design.
Both LDO1 and LDO2 remain unused.  From datasheet,
If both LDOs are not used,
the input supply pin as well as the output pins of the LDOs (VINLDO, VLDO1, VLDO2) should be tied to GND.
What about the DEFLDOx pins?
Can I assume that DEFLDOx also needs to be tied directly to GND like the other pins?
Thanks & Regards,
Binupandian S
