We are designing an MPPT solar charger for Lead acid batteries.
As per SLUSA75, Sheet 12, the lead acid batteries "After the battery has been fully charged, a float charge is required to compensate for the self-discharge".
From the charging profile of BQ24650, it has 3 cycles (pre-conditioning, constant current, and constant voltage) then charging will be terminated.
Please advise how the float charge to the lead acid batteries can be implemented with BQ24650.
