bq40z60 sense resistor minimum
Other Parts Discussed in Thread: BQ40Z60
The bq40z60 datasheet (SLUSAW3C) says that the sense resistor can go down to 3mOhm (section 9.1), but the technical reference manual (SLUUA04A) says that a typical sense resistor is 1mOhm (section 7.1).  Could anyone provide insight on what the minimum sense resistance is, and whether we need to change any registers depending on our choice? I know the eval board has a 5mOhm sense resistor on it.
I want to make sure my resistor can detect the proper negative power values (when the battery is being discharged), which reach higher currents than the 10A charging value.  Would there be any issues with this?
