LM3478 in boost configuration
Other Parts Discussed in Thread: LM3478
I have been using LM3478 chip in boost configuration in order to generate 50V from 3x1.5V battery as a supply. I have created circuit according to proposal from webench.ti.com:
As you can see from proposed schematic, in my application I don't need high current on output (~15mA).
Main problem with circuit is that for voltage lower than 4V, without load, my circuit doesn't work properly. In that case I have around 3.5 on output of boost converter. Can you please give me some explanation what can be possible reason for that,
and how can I resolve this issue?
Thank you in advance,
Djordje Radivojevic
