I am using your bq76PL36 chip, and am trying to understand the connection between the overtemperature trip setpoints and temperature. In "Table1: Overtemperature Trip Setpoints" of the bq76PL536-Q1 datasheet, there are two columns labeled "Vts Ratio Set" and Vts Ratio Clear." I understand that Vts is the ratio of thermistor voltage to REG50 voltage, but what is the difference between "SET" and "CLEAR" Vts ratios? Thanks!
Matt
