TPS73801 noise reduction
Other Parts Discussed in Thread: TPS73801
With many linear regulators the addition of a capacitor across the upper resistor of the sense voltage divider will keep the reference noise from scaling with output voltage.  Does this technique work with the TPS73801?  Are there any stability concerns?  If this is appropriate for the TPS73801, what is the proper capacitance to use (or how should one calculate it)?
