Customer configure V5ADS3CNT register to +2% so that the output Voltage is around 5.1V. After forced shutdown by long press power button, they found the output voltage is back to 5V. I check the datasheet, and found this register is under UVLO domain. I would expect it only be reset when input voltage is too low. May you help to clarify this?
Thanks!
Antony
