In my new design i will use the LM2940 (+5V and +15V version). Could you tell me if i
must use a protection diode between input and output of the LM2940 (when i have large capacitive loads)
or the protection diode is generally not needed (LM2940 has protection diode inside) ?
In which frequency i have to test my capacitors for the ESR values to match
the values in the datasheet of the LM2940?
