LM3880 / Pull up resistor on FLAGx pin
Hi Everyone,
The typical application in datasheet uses 100kohm pull up resistor on FLAGx pin. But typically 10kohm pull up is used at typical application so I think 100kohm is slightly large for pull up resistor. So can you explain the reason you use 100kohm if you have any background.
Sonoki / Japan Disty
