Using Battery Management Studio 1.3.42, GPC Packager WIPED A LOT of directories and files after I pushed "generate package" button.
An empty message box appeared. I cleared it and pressed again the button. Same message box and when I went to see the generated package, a LOT of files and directories had vanished!!
I fed him the log files from a directory and EVERYTHING in this directory and one level above was ERASED!!!!!!!!!!!!!
All that is left is the log directory I had selected the files from, but empty now, beside the shitty config.txt file that I plan to print in thousand copies and burn.
That means all my other log directories I had been keeping beside were DESTROYED. I do have a backup from yesterday but that's a full day of testing in temperature chamber and complementary work that has been wiped out. That tool just ruined about 2 days work.
I would gladly give you the files that upset the tool but guess what? They don't exist anymore!!
Remove that software version from your website before it kills again.
I run Win7 64-bit, if that can be of any help.
