Can you provide some documentation about the file format required for the GPC Packager?
The question arises because I have logged half my cycles with one version of Battery Studio (1.3.24) and the other with another version (the latest 1.3.42).
It appears that the file structures may not exactly be the same since the packager complains about that.
I noticed one version uses commas as separator while the other uses spaces. How nice... but the probem may not be only about separators.
Notepad++ helped me have all my files look very alike (all using commas now), enough alike to now get packager to complain about the header.
Along the way, I removed columns that both files did not have in common in hope of solving the problem.
At some point, the tool accepted my files but suggested a load of inexistant column headers to choose from (all those I had removed!). That was suspicious so I restarted Battery Studio.
After feeding it the SAME files it accepted the minute before, it complained again about the wrong header.
After hours or reworking the files, I finally had something looking flawless.
GPC packager finally accepted to load the files while still suggesting loads of unavailable colums for temperature, voltage and current. I just selected the relevant colums and pressed "Generate Package"
Then, the impossible happened: GPC packager WIPED OUT ALL MY FILES. Read: https://e2e.ti.com/support/power_management/battery_management/f/180/t/452839
I'll post the backup log files tomorrow expecting that someone at TI can help me get the CEDV parameters out of them.
To be continued...
By the way, I am logging off a BQ78350 device with an EV2300 (but I bet you begin to know my setup... ;) ).
