TPS5450&TPS5420 EMI/EMC problem?
Other Parts Discussed in Thread: TPS5420, TPS5450
We are using TPS5450 and TPS5420 for our project. The output at pin no:8 is distorted output. Schematic has done as per datasheet given by texas instruments. Kindly suggest to arrest the harmonics at 500KHz frequency.
Technical Clarification
1)The below circuit consists of EMI filter board. The ferrite beads and choke  are suggested by wurth electronics.
Fig.1. EMI Filter Board
2)The below circuit consists of TPS5450 buck converter from Texas instruments. As per datasheet we are designed the circuit.
Fig.2. Voltage regulator Board
The output of EMI filter is given to input of the voltage regulator Board. As we are getting EMI/EMC issue on conducted emission test.
Graphs for CE-03 is given below:
The waveforms for CE-03 is given below,
