Does the IT Enable Bit must be set in Golden Image File for Production
Other Parts Discussed in Thread: BQ27510, BQSTUDIO
i will use the bq27510. The Learning Cycle in the bqStudio Software was ok. In the End of this i have make an Golden Image File with this Tool. After this i see that the IT Enable Bit is still set. In the old TI Software the IT-Bit is cleared when i make an Golden Image File for Production.
Which behavior is now correct? Must the IT-Enable be Set in the Production File?
Best regard
