Dear,
After test the BeagleBone Black board, when adapter plug in, the system will on.
I want to adjust the power on sequence; adapter plug in->push button->system on.
Please let me know how to modify the HW or Register setting, thanks a lot!
Dear,
Simon,
Although the user can modify the power-up and power-down sequence through the SEQx
registers, those registers are reset to default values when the device enters SLEEP, OFF
or RESET state. In practice this means that the power-up sequence is fixed and a otherthan-
default power-down sequence has to be written every time the device is powered up.
Custom power-up/down sequences can be checked out in ACTIVE mode (PWR_EN pin
high) by using the SEQUP and SEQDWN bits. To change the power-up default values,
TI would need to change the EEPROM of the device.
Janice
