While I was program senc file to BQ34Z100, the software shutdown. I attempted to reprogram it but found it didn't work and gave me communication error 772. After that, I can't communicate with bq34z100.
Is there any way to exit the ROM mode?
You have to press the Execute button after you program the senc file to return the device to normal mode. It should return to normal mode as long as the senc file programmed properly. If id remains in ROM mode, then you can try programming the senc file again.
