Hi
Can I use BQ27542-G1 , for Primary lithium-thionyl chloride (Li-SOCl2) for power management. I want to use 2 battery in parallel. how can I get the model for (Li-SOCl2).
Hi
Thank you Justin and Onyx.
The flatness of OCV curve ismaking me confused about what I should use. do you have any specific part number that may be the best suits for this? I need to know when I should change the battery. like when the battery is drain about
80% I need to change the battery. Is there any other way to calculate for this chemistry ? The device for which am using the battery will most of the be on standby. how accurate its gonna be if I just use pre-measured standby current and calculate remaining capacity using equation in firmware time to time?
Tanjila
