Bq34Z100 : CC Delta limitation
Hi all,
I have a problem, I'm using a high current system with I > 32.767A. So I have a Shunt resistor with 3.3mOhms value. After current calibration I have CC Gain = 2.827 and CC Delta = 2.822.
After that, I write an optimized firmware in bq and when I try to write with bq studio CC Delta = 2.822 I have this message : "Value is beyond maximum value defined parameter". But it is the value finding by bq!
My question is, how to write my right value?
And after that, the problem is when I will calibrate 20 sample boards for current average calibration value. How I can send the good value if CC Delta is limited?
Regard, and thank you for your help,
Loïc
  • Loic,
    Please send the 0100_0_16-bq34z100G1.bqz from your C:\ti\BatteryManagementStudio\config directory and I will update the file to allow a smaller value to be entered.
    Tom
  • Tom,
    Please find file here (I have changed .bqz by .mp3 for post),
    Loïc
  • Loic
    I updated the .bqz file to allow a smaller sense resistor to be added.
    Tom
    PK3c�4qG�+�bcfg/all_data.bcfgx�AE`��z��FI��b�n�(CIs��̕OuF�����蘆(�An4�V�I��$� ]��Bh?�w�:�#�[ׇB��҉�8�ynk3�q92������
    QF��,x ��-�=D�b��+����Q՗�m�?�a�f�7�^�]��8�y�c�b��m��P�͟{N�ovHLA�Q�L9ր~��D�5P���f���dl�ʉ[1�w����e�����_�r�T\��	�+7�=�M�L�*�J4��N� �-'�T���"n���]��N/T���>Uv�i������?z��2�H�/�ģf��>�4!�MB�\�D+<�K������!_#9&�|�VI�'z���n�w���L����Dg��|�Gq�/���e[ү����t������H�B�ƫn�d����a���fh�a�;xyV(O�QJj��&�l�S9ࡃ�����ᎇ���}��4!����,��՗�U9�5H�\����'���6G��;Q/L��pʻ�.:��׈���Y�!��=Pn�8w]
    �f	�M|� 4z��+�u�^A�-ܯB�E�X��ղm�fdDߖ���ޙ2q�D
    �I2��p���Q=xܻ����Mg�>����o�
    �V@�p��0rg{=pC�`�b��&���;;�&��׿ٙU���=k>�n�_4&le	 �mi�k���zrr�/�����~9�6#�v�YTW�/y�e��ו��ҟ�-��Pt[�t1��c�*���ۣ8�C|�^5�;��'DA�sй���X�E�9�}ƹr��!n|�N"��`:V�9P�bh��Jw8j�Z�,�_���d��P���KΞ4F��8eMԋ�4��aS%�M{�Ζ��v^��k.��!6U�j2Þs����t��>��l-f���=�/\�g��v
    ���?�@jA�0���$�����h{
    4t����	4I��ɽ�h��H?O��{��uMW”���9����0}�y#�o�Ѩ��%}�������&�ۖ�A�&{��_�'W��$������*��_S���F���]�|7�U6�J|�zB��j��r�m�p3�H�)mkoC�ڔ���n�:g3l�њ�S�|�V��M"H��щ��M�����3��ٟ@	�i>�&�	/����-ߨg�;Q����qWvN͗#��bgy!�_��6�h��'�*�ɔ�@yX`��4 	�'}�`�q)~���h��Pv�X%a��k�ɡJ�j��1��̠G��#�W� ��0i�*r��
    gM�BWYh!koN�X�1I7�����?�U�f�s�|,���)�Z��4��"~B>M,���N���G#*P�;�!`1؍k��e�����ek����wkM ��B��D�`y@|�e��z3&��2-�3Z��C/��rd�3�s�Ã��e�/
    ��̬��3��@��ڪs���9�9��f8���dV�ŕ.gy��w
    ��	i_˺[��]��n&��^̏�~���HJ���Lܖ�U_9@��“Sd�/�O�8�`$�>�C⠢�BLS��2|_�v����x�YxJn�w��h�����i�#^�R��di��^ڐ����	��!���ɱ'���j�����[�	����\S�g+��z�!N���WB	x�?�Y��(�� ��5��?S�A��!�����:e���B�(p��Tj�ƣǶ�a�Z.&񁣞ʮ�[��2���06�.�Y�-����G5{<��������w�.��Jd
    �W�O�n����+���}�������Kw�=����E�Y4���$s����y��i�"�JS>oRH���z��&]�\�n獪�Fm�:��ƊZ�p2�a
    ���+����` ��1��%oq�)���c��Q����#Қ��'�d�=�P���(8�/6�$qP�u��Y�����V#�o�˹�&�b�ҭ*��92!�mPu]E�iD;2���C��ǻ`��p"�}+k҂҇���j�R��jޖ1brv����OM���kcȍ��yP���['rl(�#t�"䌽��~���$UKH�	pdI��.�~��fA<�ɤ�'�a��҂�#�S��:Q�E�`W"ݧA�)�砗�m�I8>*�_�o.Q�<���:�\���վ�7B�Y�����G���I�t���vv���=��>Ed*r��Pl8��P���l|�
    4���kD4�]�h�p��هӁ�8�ߗ^���=V<
     ���X-�k�p�cS�����q����{��
    �Z�E���}l��qyge麪`�/�>�hZm
    sT�S
    ����[�q#nu�������
    ��+tv�ś%PƯ�������\ip�[)ُ�8h��k(�Џ{�x�u�iZ3*��¿�+�����6��45��"�^i���ޕ�=R�MY�n�^࡝s�H�Ĉk�eI���_B�Xգ���
    �=B��qx�Ϯ���kf��X�y���m��KHߍp�k�i�[#@h57��ݳ)���c=�ť�T�C8�,����:~��*��oe�#��r**�%@���0�)��n���8�`��Vl��4��˖"7��&�2� �xXʤ�V�6X�g�J,U��⮽��\��- H�� �c'�aF�:aH�;U����եU�Rhx�Y�%��wYV)\�e���蓡�&פ?#8$�T1
    ŵ'�������D��-���74͕O1^��	!��_����>Ȑ%�X��l��}&,C�����7rka8ԩ�|@{�7S�����ĮA<�����Vƣe*}�����85��_K�Ĥcp��A2���=�A�w����u�yY��5�V���Dю�W���B�r�$��+,�KG��/�
    /Ŏ~����]&"��=]ϝc�Ŵ�L=R���j԰7x�Z���ʍ"���0b�mG��)���UPv��1y��w�""��p�Ŏ��U�`+k�+Qt�\<�qw�/*��ɋ�sd-�'n7����$���b�ƾ�,�"&*[8
    1���/q
    �%�vI� �T�)b^�:�J�Au�ϭx�J�Ͱ,�
    �_�d���Ʉ�©�����3�q�{�f�RIp#w`
    �s�9x�E�qc���L0�
    E�8�14����ve����u�"{N��J�Ie�dC�گ���B���Z�+g> @8B�G@���{x���jZ����@��=�����hٔ'4��viö�06òe�%`g��NҖ|��c�	�wPƖo`G����bBÄZ卵�G|��1Û8��V�P����Js�
    *C!?s�E��0��T����Y���O"�4bk].-]+.�յ�
    �-N�4Ǔ<����D�Ȍ;�V�����:g1j@�GW䏅v)w�n��U����\@1/]�����>�S<�;�a-i�)W������:S*:��D̢�������f+�*�#R���'�����N���xM=�+�E)��ygJ�Bi�;�|1+KUk�%-�F�
    �G��D��1.^��S�J�[Āh��	��Q��+�n�(��Ï��'KKii��,������{|��C�W$-t(�O�TT�8��~
    }BvD%��s�$����{��c��V��3'�_��O�b�F�`F���3�)�U��[#G���z�k(9z;�c<�^ec���D�sR8<���0�	*��F�3�޻t���
    P�G}�H��ܸ,y`��Pg�C�\�|g{4�3�k�\|R�����,�V���.w��8F.3�k�!�i��x�.�4��dC�V���I2��:��3����9��2%ZL�z�MA�[=:>����Y#�N˟ߗ��/E��� �t_r��dHefQJѻqmO)�4��”M���-�>wY?�"�I�[��V~c��g0I��:�dgjS$�e��&�Y]���"�kn��[@��y�BKB$N����u��r���٣��O�����f�1n r�j$��R*��Wb��W+��+'[�W�$��Y��K�$Y��n�2h,K�
    ƙ@n��܂�����P;�ڡ�c՗���+VS�lU'm�U�5
    �Q��d�[��~��yM'X��]7BV���c\���A7W����ΖU��0s�9BjBQ�j����?W���*�̗Դ^ݮ�oO�s�L��O�v�,�$E�Z��֊���
    ��ݥ�y|�م�NL�9D�i������w5J����i�!�Y��3��-��L$�ʇT��M�Oo�`p��]m�Q[pa{�|%O��7��L��-��mg��Ź ���������;��z*N������2Ln	ԁ� �1vp���r�~��]�FN(���1"TK�i�Cek�`A�KWL��bYc"���f�6THʘ9�5���.uۛ<�����_y���#3ӧ��2t+�'��Y�5\��J�ʴF���$�Q�&��c��)��Fd��`+��y8�7��u�R'xLb��էf�2��^�o]�#�����Z!Yl�\��$J^��	���7#`�W�l;B�&N��.k�� ��a")l>x�D����|)�8�#
    ���[��,���1�.�g	�����ˊY�m7o��»Gc��h>8����nOqe	2-����	��:�P�f�9�؃vFbKKn!��%J��d���7W=�L7�
    $����8&\(	V_,*nR�:�X&�#E��>28rŽ3&�b��`@%�AIY���,n0:�^����|�h=��8a�/��$�j,
    *�$Y)_ܸ�󌩭z�ۺ���J@,�?���V$q5j�Mt��g��j�hu�γ�6X�K�!�FI�>��(J`5�؈���y�Y�OWb-����V?Fg�Kx|m9��F���G�#-C�B��8�n� ^)B��g]�]��]Y$^�s�di�qh���lU��=3����7�5_�r?�D��o?�o�u�f�Bx���������*Ykl1���~�̴�3�I��\vz0[�B�˵9�ɺ
    �IS�%ћOD�J�b,��]4����3f���kʞ�G�͖������������qU|߉h���>��I��wƁ��,��ڰC=�ћX���ъ�2i�����F�t�(��Ѣ���	$՚V�1��O��߷FT-��r�n�"8�W=�۷|ݏʯF5��_G_�>���C)��H7�7Z�-��}�l
    ժ�M�)��*q�ջ3_��ns��lbH���򾻭���$'t#E�)�[���!�ѭؤ��d(�X��a� f'��K��q"��o�xߧ(��m�J��K��81'V~�U�	G�� �$,�Oime]m�p����U�%�`{�E��<u�sf���ˁH7�oAc[�0�Xs��K�26L�踅G1���p?�7�Kv"�
    TL\�5��c�X&��O��Db���4Y��z��v��X�'���Z=ڭ�k�4�����k�(v4����mPA�asW�]��r`�C푦�J[QTNG:��ӄ8����n�սc��F��
    '�'Q|G*ʕ�]��8�g�o������=�l{�����u��RR�����{��&�V8�ړ�:�R9'zOK��_k�s6[RH��L��6���	N���T�,�
    �(ӭ��b�f��iſ��y��x8G/tꈸO�T?��Y;j�.ql��vi��癜���I��뵼,)�=���2.\S��ɴ�1 ���B��� WF�p�8J����m�"ae%�����+��e�Ԋ��ʑ���\��z��#��3�.S~��`��?��ef����%3�E�B%z�v��<RC0Nj#��'�'�|�pI�TPf�X7sM|��gϛ�A1�r����F�7�h7��e�{И�J.a�^�y�W�9����� �2{�0���녀��j�w����Ŋdv�c%S�����.ݚ�]��y:A]��G?�.�5��b��j��+�C��ar|��.�����(�Fp𽃈���:��5���9�O&�9��}�J�hb����p5M��Ӣݎ��s��Pn?�!08�͊��BQ&���,�S,�]-���z�},��i�v��֧=u^e�
    8m��ikP������`P:�֯�=L�����޾��0Q��y���Ud�rT�8�l?(�D�}=�\7���_@�E�(�yO�A�24�Nj�S9n�9(�w�����<��D��\��D�l��wf��7؈(��J�iJ���k��>�v�!9��9�ֲu��q?��;F���`�4��Υv�<�1��?7�݂�ÓƬ�(��iS`w�a���9���#�������ɮ���~M�q�V�����:,�w���vc׌Ӌ��s���5@<㖺�52a%�dp�&�Z��;�i���|,�A�uH�A�̣�V��(�-6�����x�G�σ.3�dM��3&L~(����RON���uS@�;��5�K��N��e��3�$��)Ҟ�
    <t<���DW��LI�TRyDD(�1K����]Ҍ�}�gr�(�O�j�͠��
    �b��#���ev��T�b�V�����G	��Mr39�L-r*vA��WQ�뛩�To���E��Vy���3�V�V|�H9rP~aG[�[��^�^G[;��7��E�*)�R����j��z��P�yj6��m(=�zR�0JQxj����쭻�"KA��!�����_„yBZ?.Y�t���'�"��s��q*X���}/�h��L�	.�5����&&K�����4�p{��w(T�L�5}��4MX^���ꐄs�V3Mq�<���3hR�
    �a:��7��fG'�����04���7:!������ݞpp%0���i}�N�'�Nb��FoBr1z��<z|�P4�n-�����lnq�2�A��JTWwJ��ld��j�A\����ޓ�;��8�t�)H�_��L���~�Y||W�P�)����Y穓|-M��/���r�*����Z3��oP��˫X�v����ڂ�4�j{4�&�X���ҙL^��UAB�C�[���Z�4�D�L��h+����2q�L��EM�˹|�����N�
    ��������"v��5��@'�my�]q4	�˾��zy�2�q����ld��������O#�+?1z|yU��/:S4��~h0S�H"س���u|ɢ9���U 6c_�Wٽ��ʭ*�d��6���}RG&�;��gl��(̨�y
    �ɦ�'sZ�>�!hX�<����o�A����C�g�.��q��YL�9��F�]�'B��_CpnA�Z,� �|��l�~����ٲ}<{��JգJ���Y�$(��U���ȭ,�( [
    ��K�&��	Jw�Ls#�xm�_���oKVB-������o.@���`m�qo��0�EУ�[-���n�Q�a�Px��`&V[wG��Թ���Nr�<e+wD^j�
    �|�	��A�;�7�A�(3�a�s�I��8�����|����֤"��:�~��<h�\7��?>������Qΐ�oTmt~�̠I?�ϣ�h��Ů�)\
    ��?���Im� �:�4�[�x\s��7@0�q@)�$�Y5������X�ug^#�;��|Nr���T����%ɇg�苿L��Z+�!�۽����8�#?="�g6���r�3H`|5 �+G<���/^ž��P#/�d��-	#g"�_�<�C�w�G=p�ƞ<K���Y�@�~{#��%�"!�~���fI�w�--��~�j�Ɲ�&�:Ρ�e��[	�[S��*���*�$��D1jd���RZ��0�@�O�ggk3��~�V|��[x���Z��I���y�q�3���mʙ�D8�a�`σ	%��j�cW���GO�����d�Ro���kcjcf���*A��L^i#VJe�o9o��qF�d�̫��'Mg[�6ֳ�����/(���M��=om��q�wG�<�aA���r�@=*�gk���X<Q�!�J�׵����;�}��'�
    ^\��#q��M.���aT봿L��z�uO���������Z
    ��r&�fJk��?�
    �ѹ�KE?yiPt��"�![�kz����/�܀>�x�il��//��}d3PY�3�L��/ ����O�Ffu�/�n�㉪�e�
    ���U�[��m�,�j#��S�b$0���S��F�/Y戃q�inR�e���ʼQ-�Aኆ�\&q��4�ƧU��nK0��R�R�2�sۗF�P0�\�oTH
    }��R\~�c̦M�@| PGJD��G:ޞ�����"�A]qK���ķ�4��Vϲ�ͧ����[8��h4��r[��n����T��hK��`�Kp5��u������ţ!DR��ⷄۃ�����d7Huoh��:_,��J�K�a�1_v�'�-PV��㍕\}�r�����Pzj-�J�=8��%Kio�5lˇőxXq��&<U]L>Si�o��Kn�Ȝ��\43ҝ��rJ���v�5���Ӻ���a�߀c�		��x[��ʜ�s9HF9J
    �^�*�*l���O����|�k�R�"|�0�"D\nWz�R*ϖd�����i��[�3 ��Zh]��0e��/�*�0��_����9}��&�P��&�C�m�_�ç�;�U������u���o�E��"Y�Kv�2��279��_.�Ѫ�7����к�RЁ�3|�q��)��3	�+	���N���X����߯��*��Iд�0�OV�+v��KƂ
    < L�֖���G&�p�)~l�ru�2�U*��Y�`z����e%@�6���&�)��v��g���})�o�	���i|�	)�Wd����Δ���i����F*@c���py1�m�@�w��2���׆z�(~�Ը� �e`)���#��S^14�ηDB4�ԺګĨ^���9�nI�	_
    e�������ǠB�:4��9������a#ʏb�qe���k	�)4���Y���ݓ;��9��������C�9~��T�v�2�	p�����ozC8����PZ�\Ip�=Z�
    8I�&��o�sh�	�.�b���V����^�_o^>A�ޚ��V�ԭ�s5x���`�w桻VNK�����ߓ,Ƹ}�g�݀��e�s@H�_F�}��"�1���o����"5{F�=�G(Ghl!�
    �[�_�8�k�@s�ח�5,T-��̂eܣ�Uw�c���\����y[z��J.'�b��T�����M�`uW���Z�" v�y�5NOǨU�;�l�H�ƯA|��Jh��J�����S����Z�w�]��9����ۢ�,'ɺ��D2ǩc<�9�m�$�%��(5��j�=�QM�(�}�/��D��n�殮2s	Vq�-��y�`q�{�,!��M���,#� N?��W�S��9�)Y 3��3���X�5�G���3oi]���<�_�{�[!5��(�(��7����|
    �i���aZБ疅
    x�_�V�
    2�{h�i#^����|'�JID�v�Nٕ.�=��{��r��6�b��@r��⣏������k��znya��3����L��&��t<��gϺ���$�ꚙ��uqn͸���x�����?d���&{԰�[7��\k!7q�)6���R�6q���,���NJ�g�QW�5u��3�D:e��0���[\YJ�oq�U�&��q�1�L�GuFZ�pϬ�ܓM�zd.�:�� �;���dSN�7�Г��v����^��U��c�j����`�U"�M���z&�r�Ea�7He�]>�Z�'e	��ʕh�@@�b������2��KAX3q_����gη�d#�Yg��������GR��R	��Z����g.�f�����tYH,�6�+�� ���B�~L	�[��Y0�c�؇-��	�����a��B��9��N4�l�?�B�b��䚋��])�[yǛf�q��-�����F�;Ea��B
    ���.����_��l7�]���/ʵ�Ma;]�W�q��B���
    z�H�ގ�x�I�xi�nnó�Q,+�я�2�p�!s��g�H��,?�:j�m1�ݖ�2�o6l	^����:Rr��<�w�p;���+��>D�H[��Z�ҁԱ
    P�Xa�V1��s}�.���<9�"b֣�i^�Y�E�B�>!'����h~\�N��t��o�����Ez�xa&
    ��͑�T
    ���YǮsV�-B�q����H�	B��O�M4whkٖ�5VDP������E�I���r,��L�t횘|��e$��;�	����8��6/E�!ߕR�.9��X#6u�z������"RҜ�^؁�����ѭ�ժ�h3!�*8��f1'P�K�`�j���g��'�P��=疡�W�K!	�����c�˸�|���-#ԑ�-"�`絕�2��C�-/���N�&�=e]B;%�T"@i��$�=�[��>A��
    ;�v�I����U���8ݨ��ư��^�^�G.j̒���Z�J�-����4�W�ݟ>������?}�������+�1�ήP:>�G�/�����B<x��X�����cyh��&W��]	�r�_WG�a�@
    ����f��*��Zft]�6�'Dʇ�
    �n�����%M���k�(;e2��;�+�Ϭ⭑�R47M����-�*z_�������'��<�^�{7��0��
    ,�0�����,VOE#ї�x;�Y��EG�e����7[Q��ߨ}bZ7�F<m<A��wVЖĕh[� �z��X�����}�g*hȴk=�H�Zü�u�m24�C�ޕ!��,��X����5퇥��.D�-�����q��?LxHhd&�yN2�����s��'��
    8��Ȼ�׈
    �n0 �T�����iM�߫��B�2�� �^D`��������$!�Xōy��ma�z������1��am��Wh�S�ڨ�r�����%���^����T��>;�h�8�Ku��Y<�1!�C+!��W]@`��`����L�fZ�k��=Nl�ݫ"<t*Ө
    o��5��Z/�en�{�P!�8�����.7��:���h�cS�W�r%Ȳm��/Uv��0�_��\�-���`T���-���ň�3:�PK]uE�{��&�bcfg/main.bcfgxm��n�0E� ����NQ[9aQ�+�j+u���%?�ؐ���
    ���;gf�M7�5�(����`��q/�k*����\C"s��dO2�M��Ө�6�{����2,�;��
    ������o��b>��\(Ǡ+��ؕÀ��}��)������Ҳ�vɕK�]��O_Ԉ{��t�tr��s�5�AZ�A���LጶCgXT������)�K�u�!���5A�K�W}���6�.^:�O�������m5jY�������P�b�g�7q�̘�`���P|��I�PKNjtEȀ��!bcfg/map.bcfgx��]o�0@�[��!�{I�Q�C�:$�&Ȧ�Y7��X�Gd;�}M�k-hf���s��{��i�Y�(M���~/B�̩(g�W��~�m@��� 3�'=}����r=I��p�K�@W8���%
    r��J6��Ǚ��J��N����'a��n{�AO�2�E���j��*�ដCԌ��H����^&yh�[��ݢK��iWs���ro�sdWq3�Pz�S�^3mT��
    ��Qy�����]d�<<(������hJ
    ����<�"�6��(NE;劆��9pЁ�����}_~�) 3�"�Bc_�BR*j�$���%�5A9��H�v$�׶�x�lO9��׵&%��v����sY-YsV!C�R[~���f��p�k�)�D�lG}n�vݼ=�D���n�ǖg�����vx����(�C�F)"N*KV���y��~���ɨc�Ŀq)#ؾ��Յ�pz	���5N�wz��\è۰�������k�GC��{R;������a����9a.~���\���ِ�i��؆t��S�����_PKNjtE��D��.\sbs/default.sbsx��n�8��J{Q��f���-��(MBAC������rBK�j�a�l�|�8���J|^��y���>�}�ۖ��g�Η�S�B�|�,��:���+�.�J����<�6n�V��i)�'ܶD����b��ݖ���CNa:+7:�|��З�K=O��^#ݒ�j��	5cm�D�m�
    �+��F���_3�MwZ����AR\�G��k�
    ��r��F)M�o.�>�<�k�S�g�3�,(hh�cJ� Xz�+n۽FrDI��ʃ���oL��r?��g���������Lc�G"K��k���o�/����a�"{gi^D|H�^��CJ�:>ҁd���d瘾4��$�'*�4��^�i�/m�O��nKݠ'�_��Z&���B�E�T�,A�$�R�|d���1�ጥ���<�ŷ舱@4�.�beS��ƽF�)���[і4�>}T�z�h1mi�ީA��w$}�i� �a�/����(�\24W�L��_q�w�p��N�׌�gI��A�3kt�ҍ"���=QR�8k�Ė�ȣh�E���mIGWd��ؑ�rg��x�\�H^���"���JP6�Z�C��]�����N�fEb����D�����|O�;�4�\TF:�U�U�s��jm`:����-��R���2�N����Ma����YV�`���l֜�cή8gy��]����Aƹ����W�a����_:��8V	Vb�^vU��K~��'b5���5'�e\��C��-f�ߡ�gbJ���Z���a���m���Fه����Ͱ��RJۧ��h�iC�w�ޖ'�Q'��p�@�	Z����tj��G^O�-��q�p�|܀i��S����-��r5�_�	��
    ����}����EZ��X�&�jD���!r�%����/y���PyV�u�����0�F�
    ��8�mQ'sn�W�d�P�1���7+2b1�M{WK��\�4+�;�j���*�h�էbƪ.Bj�P�b���
    ���,~�T�Y����qSg�G؁C��L�dB�'P��ӆv7��a���Xյ��:����<�4ݐg��:,���Q@�O����k�gw}Ea�M�U�IU�U&ڕf}Y1t#Rt3
    R7=֛���l�DEF�tT6=|��i���lz>�-;nb�*kΎ)�&u�*�p:*���Ǹ�:;v�nZ�瘞T9�Kae�֥�6"�jU���ݨ�m�����k58(���߉e2�I��c9Lξ��`&���0��ep��.}%�Z��;��G��A�����h�P`.X0x��P�eb(oߏ���&k,[!"����JS)��S
    �T;�7z���W1�j6Rn"yr��T���y��q�l�D�qz�����P�k��qu�B9�Q���
    vp�F���UDF�NTm�d�"2�dH��$7����?��>{�""�
    �Z�!"�'�cx�n�[d.���~*_\#�Xɷ�$�qU���5z�A����#9R�S�;@�V[�6�I�!S]��Q����EV����{|�Q�,s��LQL���Y�,D��X����͸U����Xb��s�8XX�o$-�!%��FB!����V�I\�)u��Ma
    <�#ޗ��Xj�9a�i�.VŽ���W�Z-�mPC���}U�3E3�m����*P!+��/�j�E�<�be��Y��Uɳ���Y�������/PK�^gET+����targetinfo.xml��_o�0��'�;x~O�j�D
    i�#5c�"�-2�M��حm��/	j�!}���s�<�|]��#�9ؙ�ځ6\�!�]�Ѿ���������e�=W�ܻ!�����tu�4���TM�:��T^u���/Uu��?��ڦ�E�� ��{�pP�������j�hJ �9^��z���_��_z��>!�5H=c -�8�s
    ���~�|��[+�R%��L&o$f7Q���<�W]%����U^�>[���ϓ{�8�8x�[�EP[g�2��T���f�?I�G[�
    �a��11؍��8�^SDJf<_=3j��c*�a���R:��k�{��
    ����#8CO����l=��hT�K����-���_�E|,hle��aԑ��*��~���϶���B/��D DEɈͳ̀]�EU���������۩�PKNjtE�Q��toolcustomization/commands.xmlݘ�n�6���_m@�X�Ӥ@�B��E���n��(�(%j$�&�ޓ���$;���^:H�,J��8���<���ݥ��TLd�=�u��h��e��^��W�=�4�b�EF�{�T�ލ���,i
    a�2�B|��`�����d��H�"ZHQ���,��Ln��2�k"T�q,�R#�>;܏<����������P����ž��i��4"�(#gz̦^�vp�C�2�3��d��/�Yz�ng<s��(�=;,ov�%��$���n&�v�播���	�
    �U�;3b��}��P]H��K�h.�VH/��7�B!���9K}TEz�.؜�V8@np���^����D��X�v�o]���׸���]�1]��"}�Ӷ�M>��x�ӫ:nG��0�~"�V�	��x^4�9�.�%��>��xΰ��plv��6x����.d�<�(&����z�o�K��0s��rx�Ql��	��8"�R�~D���d���$�\���ׁ<��~��4e��4�,aTV[�Msx�vu I���_��m��E!�����S{6��	l�:�okH�x��f'BB��)PJ�*���*-�ʌ��V��@QhM�NC�V�E�e�6~�#�y,��o��;N�E`݊����'M��a?j>�(�D-��Hۢi:��<����蛮���d��6)8�9���h�4ȳ2��t��.��[�t!�0t���s�sY�E=+�o��1;�G�jc����j�շ%U��B��
    !;���7��绵��E�0�eU�U9���EhE$#sNUk�a#��ď_qs2<�'���pm18�Z��r*;:9�r,S�7/�6���Ş�
    B|e��j��`�5�8[��ߺ/��g�Z�ul�!��q�Xb��{��.��7�k��\�S�|����ƽ�KpY�iUy8���F��lPd��?�ܾ�k�J�W�5c��{�ј�'�Xv�M(:whR9��m��h��_���oPKNjtE`0��Stoolcustomization/plugins.xml��A
    1E�#x�
    ���;d����6u��SA]d����5�"���4��P���t4a�M���"+�m�|E�	�$)9��(��5)��QӍ��x�A�c�����/b�a��}(H��*RćP���g�PK�`;F�ȣ� toolcustomization/testerinfo.xml���o�0�ߗ���}t{3j��:Ch_+��ڥ-����K\�=Ҝ�9���0�bW�ɪ��+]G�+82m��34�G�u%��l��}���t�OO��e�8��mgŁ���X*�E9�o�~��=FZۉql�
    j]�j�T�̊��6{4���V
    �7�1CYG8��C%�(�������?�<SK��+��	�gLZA��;���g��_Tq�{�t�K��ʆ��6�A��>$����Q��t�ه�����+��U��e�z�L��\�j�ׁA�ڂ��#�%���U�x�ʽ�����%��	��$E��>q��κ1�J솇Ԋ_�q��=�Æ^1$q��Qz�ʫ�,-�Y����oNWi�^�4�3%��CXP1t��$����4���HZ�Y�K�
    �}���+��{�ip��i��PK�T0FpR&���toolcustomization/ui.xml�UMs� =�3�;�'�ɥ�L�$�tO��3�V6S* ���]@�L�Cz���-�} ~�n��:i�8�3@]�J��8�|}�-�ʿ~�O=��TX���FxA��S�|����gn��|4d��b8��,�{���n!��`@��rn��B4��Fy����\=�GlZ��w�o���9�E���������
    ��RX*#x�!Ŝө������})��Glp�����I*� �S�6��~Ю F�%0�RSo&���|����mVВ����1gS*d�nT��hv�ޢ+�l����k�?.����t&5�J�@(e^ac:�p��A�:PS��y\��lQT���l��@I"Q�:rk,=V���'V҇9h*ԁ
    *+�a%�4��d'w���[�w2H-��ݧ�~o3�%�>��S;����
    RE|���8��,�v��$u�-����8��r�R�Ru�\5q�s�;��ዱU����}[r����Ӊ<P��O�5+����?iS�C�X@�+Y�'�w�&���Q�7sO�.;���X�� �q�{>Jέ�m�#5f�����~�b0y�A�}N�mL��"w���V��HԿ���um8�X]G�$���*����ٷ���p'<���`֠�:�;�d��Crb:e�9�B�Ӻ�M�3ܛ�RR��DZ~ݑ ��2B������/�/PK?3c�4qG�+�/ bcfg/all_data.bcfgx
     ޠn�4!�\�C4!�\�C4!��AEPK]uE�{��&����+bcfg/main.bcfgxPKNjtEȀ��!��J-bcfg/map.bcfgxPKNjtE��D��.\���/sbs/default.sbsxPK�^gET+������h6targetinfo.xmlPKNjtE�Q����L8toolcustomization/commands.xmlPKNjtE`0��S��P<toolcustomization/plugins.xmlPK�`;F�ȣ� ��=toolcustomization/testerinfo.xmlPK�T0FpR&������>toolcustomization/ui.xmlPK		��A
  • Tom,
    I have retried with your file and my problem is solved !!
    Thank you,
    Loïc
  • Hi Tom,
    I have the same problem. I tried the file you posted but it hasn't solved my issue.  My CC delta is 2.750 mohm.
  • \You can try this bqz file. Please it in this directory.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/196/8623.0100_5F00_0_5F00_16_2D00_bq34z100G1.bqz
