Hi team,
The datasheet states that the flash memory can undergo 20k write cycles, with hardware ECC algorithm implemented. Given this, how many fault logs in total can we expect to write to flash memory over the device’s lifetime?
Thanks!
Hi team,
Thanks!
It is hard to tell.
If two faults happen at the same time (within milliseconds), they will be written into flash in the same cycle. If two faults do not happen at the same time, they will take two cycles to write.
Zhiyuan
