I am looking to speak with an applications engineer, specifically as related to battery charging IC’s. The application requires that I am able to charge LiPo (lithium polymer) cells that are arranged in series. Specifically 6s1p @ <3500mAh each cell. The required voltage output of the assembled battery pack is 24VDC~ . I am not constrained to a particular charge supply voltage, as I will source a power supply adapter once I am able to narrow my search for charge IC’s that can facilitate my needs. Any help would be appreciated.
