Hi all. We're using a BQ27621 fuel gauge on a single cell lithium-ion battery. We've found that we get vastly different SOC values from the fuel gauge if it is initialized at no load, charging, and 1C load conditions. Judging from the forum post here () it appears that we should initialize the BQ27621 under no load to get the most accurate readings. However, from the datasheets, we find quotes like:
"The fuel gauge estimates charge and discharge activity by monitoring the cell voltage. Cell impedance is computed based on estimated current, open-circuit voltage (OCV), and cell voltage under loaded conditions." page 9, bq27621-g1 Data sheet
"The total battery capacity is found by comparing states of charge before and after applying the load with the amount of charge passed. When an application load is applied, the impedance of the cell is measured by comparing the OCV obtained from a predefined function for present SOC with the measured voltage under load. Measurements of OCV and charge integration determine chemical SOC and chemical capacity (Qmax)." page 7, bq276121 Technical Reference manual sluuad4c.pdf
Which is correct? If we want accurate values, should we initialize the BQ27621 with the battery under load, or with no load? How much does the accuracy differ in either situation? Should we never initialize it while the battery is charging?
Thank you very much for your help.
