I try to calibrate the ADC gain and offset of BQ76940.
I found each channel has it's own gain and offset.
Are there 15 ADCs in BQ76940 ?
ADC accuracy in data sheet about +/- 40 mV,
Why it is so big ?
Why it is so big ?
Each of the 3 cell groups has an ADC, or 5 inputs to an ADC. The ADC is not perfectly linear, and each input will have some variation into the ADC (see figure 6-2 ), so each input has a different gain and offset. The part provides an average gain and offset stored in the device. The tolerance allows for variation between the inputs.
You may want to use the average gain and offset, apply your own additional offset calibration at a point of interest, use a different calibration scheme perhaps using a 2 point calibration per cell, and possibly use the method in the datasheet figure 7-2 of referencing the battery stack voltage to correct for changes over conditions or time.
