I would like a confirmation that we can tie the pin MODE / Data pin directly to VIN on the TPS62420. According to the spec, this is an open-drain pin, but the "ACK" should be driven low only if an exact sequence of bits has been send. So I assume that it is OK to connect it directly to VIN if I want to disable the POWER SAVE mode.
Denis
