Hi
We designed UCC28600's fly back circuit with trans by using [UCC28600 Design Spreadsheet](SLVC104).
We investigated the way to be up efficiency.
We found that its way was to change how to wind wire of trans.
Page 5 of [Design Considerations for the UCC28600](SLUA399B) has Figure4 "Example of a Recommended Transformer Design".
Figure4 has that Bias is between Secondary triple insulated wire and 1/2 Primary.-A
However,its way to be up efficiency has that Bias is between Inslation tape and 1/2 Primary.-B
If Bias position changes from A to B, we are worry about [UCC28600 Design Spreadsheet] value.
Because [UCC28600 Design Spreadsheet] value may have the value calicurated with trans based on Figure 4.
Please teach us the action we should do,if we change Bias position.
And teach us the changing points that its action is infuluence with parameters of [UCC28600 Design Spreadsheet](SLVC104).
We will change the circuit value based on its changing points
Mitsuo Hirata
