Hi all,
In general, besides Design Capacity, Design Energy, Terminate Voltage and Taper Current, are there any other registers I should be concerned with if I was to switch battery type in the GDK/EVM test setup? For example, let's say I ran a 500mAh battery for a dozen cycles, but wanted to change to a 2000mAh battery. Are there other registers I should reset or reprogram?
Could I also please get a factory default programming file for the bq27245EVM-G2A?
Thanks!
Jason
