I am newby in electronic and try to design a 4S2P lithium ion battery pack charger. I will use 4s2p ( 8 * 3000mAh li-ion battery - 0.5c)
I am planning to design two pcb for BMS. First PCB will be a protection and balancing unit and will be soldered to batteries. I am planning to use S-8254A IC / or a similar TI IC and mosfets (like this PCM) in first PCB.
Second PCB will be a charge controller/fuel monitor. I am planning to use one of this ICs. Maxim MAX1758 / Linears LTC4006 or TI's BQ40z60
Second PCB will also include Charge inputs and USB output, 14V output.
But i want to use only TI ICs in design.
Can you suggest ICs for this kind of design.
Thank You
