*Query*
Other Parts Discussed in Thread: BQ20Z655-R1
Hi. I got an error message to "Max IR Correct" checksum error. (bq20z655-R1) How to fix it. Thank Laďa
    First, please make your post titles an actual description of your question or situation. In you case something like this would be great:
    "Clearing Max IR Correct for bq20z655-R1" This gives the part number and a brief intro to the problem and shows that you took the time to make a thoughtful post for your question respecting everyone that uses these forums and might need the information made available by your post.
    That being said. Your question.
    How did you get this error? Are you using Battery Management Studio to look into the I2C lines?
    Here is a link to the Technical Reference Manual which covers the details of the device in greater detail that the datasheet (at least when it comes to the device registers).
    That being said I have not explicitly found the error you are referring to. What is the register name/address?
