Making -5V from a 5V supply (2A output min)
Other Parts Discussed in Thread: LM675, TPS54560, TPS7A33, TIDA-00270
I'm looking for a solution to generate a -5V from a +5V supply. It needs to provide at least 2A of output current. Ideally low noise as it's for an audio application (so I'd rather not use a buck convertor).
I thought about using a LM675 into an inverting configuration, but its supply voltage needs to be much higher than the input voltage (and I can't use +/-15V in my system).
Is there anything you could recommend?
