TPS61240YFFR LAND PATTERN
Other Parts Discussed in Thread: TPS61240
I would like to have your recommendation for land pattern for the TPS61240YFFR (I coudn't find it in the datasheet).
Another question: In the datasheet it's written for the device height is between 0.12 to 0.3 mm. This tolerance is bit crude to me. What is the reason for this wide range? Do you have more precise number?
Eli
