Hi team members,
Min sum value of Vout setting register on TPS51367 can be found 67Kohm on page 14 in data sheet.
Then, how much value is maximum ?
Kenji Ito
Hi team members,
Kenji Ito
Hi Itoh-san,
1. the outsourcing capability of REF is 300uA, that is why min sum resistor is 67Kohm
2. refer to figure.31, REFIN is the input of an op-amp, ideally the input bias current of op-amp is 0, but actually it still draw some input bias current in <1uA (max) range, so suggested maximum resistor is no more than 10 times min, that is 670kohm, in order for proper op-amp input bias current
