One of my customers is using the IR36021 power regulator with their T1040 design. This is good for a 40-60A design but their needs is less than 10A. They are interested in LP8758-B0. Do you see any issues using this part? Their current board does not use microvias but uses differential remote sensing for this supply. Is there a way to make the layout work without microvias, given the tiny 0.4mm ball pitch of this component. Are microvias basically required in order to use this part? Please advise.
Mehrdad.
