bq40z60 - LED driver FET capacitors?
Other Parts Discussed in Thread: BQ40Z60
The evaluation board of the bq40z60 has a 330k + 1uF LP-Filter in the gates of all LED driver FETs. Nothing is mentioned about the reasoning behind. Is this RC-Filter required or can it be removed by connecting the FET gate directly to the TSx pins of the bq40z60 ?
The bq40z60 Manual claims on page 80 that "The LED support is available even if thermistors are used or if BTP IO support is enabled." Do they not interfere with each other when on the same pin?
Fred
