LM5060 disable overcurrent fault
What is the recommended way to disable the overcurrent fault? Should the SENSE pin be directly connected to the OUT pin?
  • Hi Avik,
    Welcome to the E2E forums!
    EDIT: We do not recommend tying SENSE to the OUT pin as the overcurrent fault is a comparator looking for when VSENSE - VOUT = 0V.
    Instead, we recommend choosing a high Rs value to ensure that the overcurrent fault threshold is well above your max load current.
    Thanks!
    Alex
