We are facing issue on AM3354 Processor Power ON reset.
we are uisng TPS65910A31A1RSLR PMIC, we observed all the power supply rails are sequentially coming up as per the boot configuration. nRESPWRON goes high after all the power rails are stabilized.But the processor is not booting during power-ON.
Debugging point we observed,
- 24MHZ clock is coming before the reset release, as expected.
- All the power rails are stable before reset release, when probed at the processor end decaps
- Internally generated source voltage levels are stable, as per datasheet recommendation to verify the power input to the processor.
Please suggest the solution to Power ON the processor without manual resetTPS65910 POWERING ISSUE.pdf
